Building a block....question for the experts.
Old Aug 18, 2002 | 05:25 PM
TedR719's Avatar
Default Building a block....question for the experts.
Ok I was wondering what I have to do different with this setup since I'm putting together a block by pieces.
First I have a bare B16 block.
I also have a b16 crank, but from a different motor.
Now I've heard I have to run oversize bearings, is this true?
Also when I got my crank the guy sent me these supports that look like a U shape then flat at boths ends (what are these)?
I'm planing on learning alot with this build up. Hopefuly the hatch will be on it's way to boost
Old Aug 18, 2002 | 08:01 PM
TedR719's Avatar
Default Re: Building a block....question for the experts. (futuresi)
Old Aug 18, 2002 | 08:11 PM
BlueSi2k's Avatar
dont know about the bearings but the piece your describing sounds like the main caps that hold the crank in place...the bearings go inside these caps...hth
fast[R]'s Avatar
You don't need oversized bearings only if you machine the crank. The U shape supports are to bolt the crank to the block, no pic that's what I thinck or rod caps
[Modified by fast[R], 5:28 AM 8/19/2002]
Old Aug 18, 2002 | 10:26 PM
Flamenco-T's Avatar
Default Re: Building a block....question for the experts. (BlueSi2k)
half of the main bearing (5 total) is a simple U shaped
the other halves is U shaped with grooves running down in the middle for oil to pass on through
the rod bearing is all the same for all 8, each of them has a notch on one corner on one end.
Old Aug 18, 2002 | 10:28 PM
Flamenco-T's Avatar
yeah, that's the caps, there should be five of them, and each of them is numbered with an arrow pointing at one direction ( timing belt)
Old Aug 19, 2002 | 12:48 AM
TedR719's Avatar
Default Re: Building a block....question for the experts. (Flamenco-NA)
Thanks. The main caps was the object I was talking about.
So the bearings that go inside the caps should be replace with new ones right?
Also can I reuse the bolts that hold down the main caps or should I replace those?
[Modified by futuresi, 9:49 AM 8/19/2002]
Old Aug 19, 2002 | 01:23 AM
deviant1's Avatar
are you putting everything together using the clearances in the helms manual? and using plastigauge and all those other tools to measure stuff? or are you just bolting stuff together? i REALLY want to learn how to build a block up. like, bare block to the point where you just bolt the head on. using aftermarket parts of course. anyone got any sites? or info?
Old Aug 19, 2002 | 07:07 AM
BlueSi2k's Avatar
Default Re: Building a block....question for the experts. (deviant1)
check out the f/i buildup howto at c-speedracing.com...very helpful
http://www.c-speedracing.com/howto/m...ild/build.html
hth
Old Aug 19, 2002 | 10:27 PM
TedR719's Avatar
Nice didn't see that on C-Speed's site. Good stuff
Right now I'm just trying to piece everything together , then after I collect all the parts I will start turning the wrench.
Old Aug 20, 2002 | 12:07 AM
miller's Avatar
hey man good luck with your buildup and if you ever need any help just throw me an IM
2000BoostedEX
Aug 10, 2008 07:18 PM
jweller
Apr 1, 2005 07:02 AM
SpeedDreamz.com
May 19, 2004 08:34 PM
S13 slide
Dec 2, 2002 05:54 PM
canuck-mx6
Jun 3, 2002 04:38 PM
