Going to have head work done
Old Mar 18, 2004 | 11:57 AM
RedTegLS's Avatar
Default Going to have head work done
I have decided to get my head looked at. Hahahaha I think I am going to send it to portflow. Now, the real question is, what all would you have done if you were sending yours? Upgraded valve train? Ferrea valves? Springs? Retainers? I would like your opinions.
I am trying to make the most power I can while staying under 12psi on a stock block. If and when my motor goes that will be a different story.
Old Mar 18, 2004 | 12:11 PM
StrokedPSI's Avatar
Default Re: Going to have head work done (RedTegLS)
you ever think about doing the bottom end instead? For the same amount as you'll get charged for the head work (P&P,valves, rets...etc) you could get a set of pistons, eagle rods and a block guard and get a lot more power. Just a thought but hey...it's your dime.
Old Mar 18, 2004 | 01:43 PM
Trak_Day's Avatar
New User
when i was thinking baout getting some head work done i was looking into Portflow also. I was planning on going ferrera valvetrain with .5 over valves. But i opted to not build the head and just do the bottom end and boost it. The stock honda heads are good for alot of hp. so why not just leave it stock and build the bottom first?
Old Mar 18, 2004 | 02:46 PM
ek9turbo's Avatar
i would build the block first, but if u already took a decision then i would upgrade the springs and retainers
Old Mar 18, 2004 | 03:02 PM
93LSivic's Avatar
Default Re: Going to have head work done (ek9turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9turbo &raquo;</TD></TR><TR><TD CLASS="quote">i would build the block first, but if u already took a decision then i would upgrade the springs and retainers</TD></TR></TABLE>
He has an LS.
The non-vtec's suffer the most due to the head not flowing for ****. I first would do the bottom end, but if money allows then go for the head as well.
In my built LS I had a pretty sick head setup. It went as follows: +1mm Ferrea intake and exhaust valves. Portflow guides. Crower Race valvesprings--the better of the 2 they offer. Stock retainers for strength and longevity. Sick port job, basically if the valves were lopped off then it would be a race-only port job. 5 angle valve job and valves backcut to match.
Just needed cams, but I sold the head before I had a chance to run a set.
One important thing. If you decide on valves, make sure you have the seats touched. If not then you could easily lose lots of power.
Old Mar 18, 2004 | 03:36 PM
RedTegLS's Avatar
Default Re: Going to have head work done (93LSivic)
See the thing is I can buy an LS head for next to nothing and ship it for cheap. A block costs more and a lot more to ship. Sleeves are about $800 right? So is head porting. Pistons and rods are a lot more than valvetrain though.
Old Mar 18, 2004 | 04:39 PM
93LSivic's Avatar
Actually. You can buy my head that I described above from the present owner. Here is his FS thread. Pics are worth a thousand words.
https://honda-tech.com/zerothread?id=759146
Old Mar 19, 2004 | 11:53 PM
Mr.DC2TurBo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Actually. You can buy my head that I described above from the present owner. Here is his FS thread. Pics are worth a thousand words.
https://honda-tech.com/zerothread?id=759146</TD></TR></TABLE>
too bad he bent the valves, I would have been interested in them
Old Mar 20, 2004 | 07:10 AM
riceburnah's Avatar
Default Re: Going to have head work done (Mr.DC2TurBo)
i have extra head if you need it (cheap) but I"m having my ls built right now I did itr valve train and a 3 angle valve job. That cost me about 700 but it included refreshing the block
Old Mar 20, 2004 | 09:03 AM
93LSivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">
too bad he bent the valves, I would have been interested in them</TD></TR></TABLE>
Ferrea valves run about $26 dollars each. Pretty cheap to replace if you ask me.
DeLucia
Sep 3, 2012 02:13 AM
projectef
10
Jul 19, 2006 07:37 AM
projectef
Jul 13, 2006 07:41 AM
JDM00SI
Jan 3, 2006 11:45 AM
ScottEK
Dec 3, 2004 12:55 PM
