build question
Old Oct 31, 2007 | 11:49 AM
watacanga's Avatar
Default build question
if i get golden eagle sleeves rated at 1200hp on a b16a block. what else do i have to do to be able to make around 500whp? the turbo i'll be running is a gt35r .63 .82. do i need to do any head work or just push boost?
Old Oct 31, 2007 | 01:25 PM
urbansi's Avatar
Default Re: build question (watacanga)
Some GSR or ITR cams are always a nice addition to making good power as well as an intake manifold like the edelbrock unit. Proper pistons and rods obviously, and assembly will be key, as well as tune. A well designed manifold should not be over-looked either
There are plently of people making big numbers on stock heads and cams.
Old Oct 31, 2007 | 01:51 PM
Schister66's Avatar
Man U FTW
stock head will work, but a built p-n-p head will work better...since it is more efficient, you'll make more power at the same boost level
MShonda
Sep 14, 2010 05:14 PM
1baddturbosi
Aug 31, 2007 06:00 AM
vtecnition
Nov 23, 2006 04:00 AM
tncivic-dvsb
21
Jan 1, 2004 09:25 PM
autoEXturbo
Sep 13, 2002 06:12 PM
