btm or itc?
Old May 15, 2003 | 03:53 AM
turb's Avatar
Default btm or itc?
what's the difference between the two? which is better for a boosted b16a running on the afc hack?
Old May 16, 2003 | 02:49 AM
turb's Avatar
Default Re: btm or itc? (turb)
nobody is using btm or itc?
Old May 16, 2003 | 03:05 AM
NOSED_CRX_VTEC's Avatar
I'm using the btm set at 0.5dig per psi and it works good.
Old May 16, 2003 | 08:31 AM
MiraiZ's Avatar
Default Re: btm or itc? (NOSED_CRX_VTEC)
does the same basic job...
Old May 16, 2003 | 10:08 AM
Sonny's Avatar
The BTM will retard timing based on the amount of boost present.
The ITC lets you retard in blocks of 1000 rpm. It is not boost aware.
For what you want to do, the BTM is cheaper and will do a better job, IMO.
Sonny
Old May 16, 2003 | 01:20 PM
ion_four's Avatar
Default Re: btm or itc? (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">does the same basic job...</TD></TR></TABLE>
wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Sonny
Right
Old May 17, 2003 | 05:12 AM
turb's Avatar
Default Re: btm or itc? (ion_four)
so on my vafc hack i'm better off with a btm? i've read that the vafc hack advances timing so will the btm be able to cut it? do i have to retard more the .5psi per pound of boost to compensate for the advance in timing brought about by the vafc hack?
how much should i retard per pound of boost when using the hack? i'm currently boosting 7psi on my setup. i'm using stock timing on my ditributor.
asianspeed
Dec 4, 2007 07:01 PM
jetlude
Nov 21, 2006 08:37 AM
MarkAngelo
Sep 30, 2004 05:12 AM
ATS*Mark
May 24, 2004 01:59 PM
SJP0tato
Nov 6, 2003 11:19 PM
