Breaking in on stock ecu
Old Jan 30, 2006 | 03:18 PM
OrangeBoost's Avatar
Default Breaking in on stock ecu
Ive been told to break in my engine initiall on the stock ecu and injectors.
I am bored .020 over and went from the stock 9.5:1 comp to 9:1.
Are these variations comined enough to create a lean condition?
Old Jan 30, 2006 | 03:20 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Breaking in on stock ecu (OrangeBoost)
no you should be fine
Old Jan 30, 2006 | 03:28 PM
beerbongskickass's Avatar
Default Re: Breaking in on stock ecu (HybridcivicLS-T)
I'd go straight to the dyno and then the street to tune it if you can.
Old Jan 30, 2006 | 03:30 PM
MI KENT's Avatar
Default Re: Breaking in on stock ecu (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">I'd go straight to the dyno and then the street to tune it if you can.</TD></TR></TABLE>
stock ecu will run the engine but it'll probably wash the rings out
Old Jan 30, 2006 | 03:34 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MI KENT &raquo;</TD></TR><TR><TD CLASS="quote">
stock ecu will run the engine but it'll probably wash the rings out</TD></TR></TABLE>
How do you figure that. If he is running stock injectors, the stock ecu is the way to go.
Old Jan 30, 2006 | 03:38 PM
GOT14U's Avatar
it sounds fine 1 suggestion do a street tune first then u work any bugs out on a dyno
Old Jan 30, 2006 | 04:17 PM
Default Re: Breaking in on stock ecu (GOT14U)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOT14U &raquo;</TD></TR><TR><TD CLASS="quote">it sounds fine 1 suggestion do a street tune first then u work any bugs out on a dyno</TD></TR></TABLE>
My tuner works only on the dyno and I want to break it in first. Also, I need to get the car to the shop somehow.
Old Jan 30, 2006 | 04:22 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost &raquo;</TD></TR><TR><TD CLASS="quote">
My tuner works only on the dyno and I want to break it in first. Also, I need to get the car to the shop somehow.</TD></TR></TABLE>
No tuner works soley on the dyno. If they do there is something wrong. You can't immitate real conditions on any dyno.
Old Jan 30, 2006 | 04:24 PM
Why would you want to break it in first before tuning? Don't you think it would be a better idea to have the A/F perfect before you do any driving? I mean you really have no idea if it's lean or rich. Stock ECU and injectors are fine, but I wouldn't put a bunch of miles on it just yet.
Old Jan 30, 2006 | 05:06 PM
Jdm_Ek_Hatch's Avatar
Get a base tune on there and then bring it to Tapp's once the motor is broken in
Old Jan 31, 2006 | 07:52 AM
With some downloaded basemap I dont know if Im going to wash out my cylinder walls though.
Old Jan 31, 2006 | 07:56 AM
flip1199's Avatar
Default Re: (OrangeBoost)
dont waste your time on a break-in. break it in on the dyno or some street tuning.
Old Jan 31, 2006 | 08:24 AM
Default Re: (flip1199)
My concer is that if the rings havent sealed will that not create excessive blow by in boost?
Old Jan 31, 2006 | 08:31 AM
flip1199's Avatar
you dont need 500+ miles to get the rings to seal.
Old Jan 31, 2006 | 09:10 AM
GOT14U's Avatar
6 MILE BREAK IN TIME THAT'S ALL YOU NEED BRO
Old Jan 31, 2006 | 09:52 AM
donkiman's Avatar
seems like having the tuner break it in while connected to the dyno would be the obvious decision.
Old Jan 31, 2006 | 03:34 PM
Ok. But there is still the logistics of getting it to the shop. Maybe Ill have to tow it?
Old Jan 31, 2006 | 06:49 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeBoost &raquo;</TD></TR><TR><TD CLASS="quote">Ok. But there is still the logistics of getting it to the shop. Maybe Ill have to tow it?</TD></TR></TABLE>
If you have the resources that is a definite options. The only shitty thing about that, is if you have problems the "tuner" becomes your mechanic. And that can be a pain in the *** sometimes.
Old Jan 31, 2006 | 08:12 PM
Default Re: (93turbo16)
Ya...but I dont know what else to do. Everything seems to be a risk.
Old Jan 31, 2006 | 08:33 PM
HiProfile's Avatar
So it's basicly a stock motor, just a slightly bigger bore, bit less compression, and a turbo? I don't see an issue with the stock ecu, assuming you keep the wastegate open to prevent boost. You need to be richer than 10:1 to really mess with the rings, and you probably would need to do it for a while to affect them from seating properly.
What I would suggest is at least 2-3 WOT passes to dial in the AFR's, do a few more WOT pulls to tune it a bit better, then break it in with WOT pulls. Unfortunately, not everyone has a laptop, wideband, and a crome/uber basemap. For everyone else, there's Visa
Old Feb 1, 2006 | 06:39 AM
Default Re: (HiProfile)
I was going to tune myself but decided that between purchasing a wb/ostrich/dyno time I might as well just pay to have it tuned.
Old Feb 1, 2006 | 06:48 AM
ELSpool's Avatar
Like I said before, break it in the on the dyno, your rings take all of 5 minutes to "seat" on initial start up.
Old Feb 1, 2006 | 11:02 AM
SSBPGSR's Avatar
Default Re: (ELSpool)
why dont you let it idle for 10 minutes between 1000 and 3000 RPM, shut it down, change the oil. tow it to the dyno and tune it?? all this drive it for 500 miles BS pisses me off. the rings will seat in the first 10 minutes and your ready to tune.
954bballer091
Sep 13, 2008 07:38 PM
CeeJayy
Jan 29, 2007 08:03 PM
campbuds
64
Jul 24, 2006 03:55 PM
tempuus
Nov 13, 2005 11:55 PM
95excoupe
Feb 26, 2005 07:49 PM
