lsvtec kit with -4an lines
Old Jan 28, 2006 | 09:57 AM
komat's Avatar
Default lsvtec kit with -4an lines
im getting ready to build my lsvtec kit. I was looking at evans-tuning.com web site. he recommends not to use the -6an line that comes with the golden eagle kit. Does anyone know what fitting will i need to change the -6an to -4an line.
Old Jan 31, 2006 | 03:10 PM
komat's Avatar
Default Re: lsvtec kit with -4an lines (komat)
anyone having problems with the -6an line on the GE lsvtec kit?
Old Jan 31, 2006 | 03:59 PM
porsche997dc2's Avatar
I had use the kit twice and like it. What problem does it have?
Old Jan 31, 2006 | 04:00 PM
komat's Avatar
Default Re: lsvtec kit with -4an lines (porsche997dc2)
i believe jeff evans said that sometime it will drop the oil pressure too much and vtec wont work
http://forums.evans-tuning.com...c+kit
Old Jan 31, 2006 | 04:16 PM
I wouldn't worry it. It's very rare. If oil pressure drop during vtec engagement then just change it to -4 line. The line is very easy to change anyway.
Old Feb 1, 2006 | 11:07 AM
tgreaves's Avatar
Where is the reasoning in this.. Once the line is filled with oil how would the pressure drop.. I mean, you could use an10 line for an lsvtec and it should still work great.. The pressure isnt going to expand the hose that much to cause a pressure drop..
The only way it wouldnt be enough pressure is if you were flowing more oil out of the hose than whats comming into it and if thats the case, going from an6 to an4 would make the problem worse..
Old Feb 1, 2006 | 11:22 AM
LST2's Avatar
Default Re: lsvtec kit with -4an lines (tgreaves)
I actually had to change from a -4an to a -6an b/c I was not getting enough oil volume to spool the vtec solenoid. I would try the -6an first ... it should work.
Old Feb 1, 2006 | 11:34 AM
tgreaves's Avatar
Default Re: lsvtec kit with -4an lines (LST2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LST2 &raquo;</TD></TR><TR><TD CLASS="quote">I was not getting enough oil volume to spool the vtec solenoid.</TD></TR></TABLE>
Since your agreeing with me, ill leave that one alone..
ivan93egreppin210
Jun 6, 2008 09:04 AM
D-rush08
Aug 20, 2006 12:17 PM
mattEG
Aug 30, 2004 08:38 AM
Xerxes
Jan 30, 2002 10:29 PM
