brass return line barb
Old Oct 21, 2006 | 04:19 PM
si0385.'s Avatar
Default brass return line barb
how you you put them in the oil pan, i was told to braze it and than jb weld it but didint really wanna go that rout..
is there a kit that anyone makes to put the barb on the oil pan with out brazing it
Old Oct 21, 2006 | 04:37 PM
EK k kay's Avatar
Default Re: brass return line barb (si0385.)
Braze? I just drilled a hole slighly smaller than the threaded part of the fitting and screwed it into the oil pan with a flat washer. Then I used a washer on the inside of the pan along with a nut and tightened it. I then put a lot of jbweld around the washer, nut, and fitting on both sides. No leaks whatsoever.
Old Oct 21, 2006 | 06:29 PM
B18C Turbo's Avatar
Default Re: brass return line barb (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Braze? I just drilled a hole slighly smaller than the threaded part of the fitting and screwed it into the oil pan with a flat washer. Then I used a washer on the inside of the pan along with a nut and tightened it. I then put a lot of jbweld around the washer, nut, and fitting on both sides. No leaks whatsoever.</TD></TR></TABLE>
You can do that
The first pan I did I brazed the outside, and JB welded the inside, no leaks.
My second pan I TIG welded both inside and outside no leaks.
Both pans used a brass fitting
Old Oct 22, 2006 | 05:25 AM
si0385.'s Avatar
where did you find the nut ive been to 2 hardware stores and cant find a nut with the NPT thread
Old Oct 22, 2006 | 09:19 AM
EK k kay's Avatar
The brass fitting is a pipe fitting and is tapered (sp?) so the nut won't spin over it easily like regular nuts and bolts do. Just bring it to a hardware store and find a nut that will work on it then you have to tighten it until it's snug.
Dc295kid
Nov 18, 2008 12:54 AM
MBlake55
Mar 8, 2006 06:11 AM
Novtecdohc
Aug 31, 2005 04:29 PM
Layziebtnh055
May 16, 2004 10:09 AM
dan89crxsi
Feb 24, 2004 10:43 AM
