BOV vacuum line install
Old Nov 21, 2002 | 09:08 PM
Troy's Avatar
Default BOV vacuum line install
Can someone post a pic of which exact vacuum line to hook up the line running to the BOV? Im not a car expert, so when people say "vacuum line", I have no clue where it is. Any help is appreciated.
Old Nov 22, 2002 | 05:03 PM
Troy's Avatar
Default Re: BOV vacuum line install (Troy)
anyone?
Old Nov 22, 2002 | 05:09 PM
DaveSi's Avatar
I dont have a pic, but I would say that any vacume port off of your intake manifold should work. What kind of motor? I just used the port that my cruise control ran off of. When I removed the cruise control.
Old Nov 22, 2002 | 06:19 PM
Tofurky's Avatar
Default Re: BOV vacuum line install (DaveSi)
just T off any vacuum line off of the intake manifold. on a gsr there is a vacuum line coming out of the back center of it. i had a funny pic of this a while ago. in fact i think i'll look for it now.
Old Nov 22, 2002 | 06:23 PM
Tofurky's Avatar
Default Re: BOV vacuum line install (Ruckus138)
muhaha. i found it....
i'm assuming this is line your talking about. there should be a diagram on the underside of the hood of your car that shows the vacuum sources off of the intake manifold.
Old Mar 29, 2005 | 06:43 AM
DMax013's Avatar
Default Re: BOV vacuum line install (Tofurky)
old post but seems as though it might help me. that pic isn't loading also I dont have a GSR im boosting my b18a1 and can't find a good vacuum line..well actually im just being over-cautious and would like a pic of which line i can actually use. if anyone can help please do, i'm sure other ppl out there could use this. Thanks guys
Old Mar 29, 2005 | 06:56 AM
DurboDug93's Avatar
Default Re: BOV vacuum line install (DMax013)
you can use any vacuum line coming off of the intake manifold. An easy one would be the fuel pressure regulator
Old Mar 29, 2005 | 08:58 AM
DMax013's Avatar
Default Re: BOV vacuum line install (DurboDug93)
i used that for my boost controller (greddy profec b spec 2), and I still need my BOV and boost gauge put somewhere. I searched and found T'ing too many times is no good and I'd like to avoid getting a multi port thing, but If I have to I will. Say I were to get one, where would I run that from? In the mean time I'll continue searching..
Old Mar 29, 2005 | 09:58 AM
crex23's Avatar
Just buy a Golden Eagle vac manifold, their like $35 shipped. You tap into your brake booster line for vacuum, and the mani has about 6 ports.
DurboDug93's Avatar
Golden eagle makes a vacuum manifold for multiple vacuum sources. I think its around 35 bucks. I would think you could just run that off of a larger vaccum source like your brake booster line or maybe where your pcv hose runs into the manifold, but im not sure on that. I plan to just use multiple t's. I have a Profec B, boost gauge and BOV i will be running as well
Old Mar 29, 2005 | 09:59 AM
dustin's Avatar
Or use the mcmaster manifold:
Old Mar 29, 2005 | 10:19 AM
DMax013's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DurboDug93 &raquo;</TD></TR><TR><TD CLASS="quote"> I plan to just use multiple t's. I have a Profec B, boost gauge and BOV i will be running as well</TD></TR></TABLE>
When researching vacuum lines I came across a thread that asked about the line being too long from the wastegate. The response was "the length of the line isnt wat will lessen vacuum but more too many T fittings" err somethin to that extent..
ericstambaugh07
Apr 8, 2007 10:54 PM
turbotime
Apr 23, 2006 08:25 PM
EM1specR
Mar 15, 2005 01:17 PM
.David
Jun 8, 2004 01:10 PM
