Turbo backpressure question?
Old Mar 29, 2005 | 07:24 AM
Pikachu's Avatar
Default Turbo backpressure question?
I'm debating if I should go do a full 3in exhaust or keep my current exhaust setup (2 1/4-1/2 piping) and just use an ecutout. I plan to run about 7-8psi with my GT35R and 15-17psi at the track. If I run 7-8psi, I don't wanna keep the ecutout open. Will that be bad for turbo wear?
My goal is to try to quiet my exhaust when driving to the track so I can atleast hear my radio. Are there any suggestions on how to make a 3in exhaust quiet? Thanks in advance guys.
Old Mar 29, 2005 | 08:18 AM
H22A_NeThing's Avatar
Default Re: Turbo backpressure question? (Pikachu)
Go 3 in, exhaust can almost never be too big on a turbo setup, power depends on the pressure differential accross the turbine.....and running 15-17 psi at the track, you'll be glad you went 3 in for sure (it'll make a big difference in power).
And with turbo cars, the exhaust usually isn't very loud anyway (turbos are pretty effective mufflers) depends on the exhaust system you use.
Old Mar 29, 2005 | 09:33 AM
turboEGhatch's Avatar
A turbo car's exhaust is nothing like a N/A car's exhaust, it's so much quieter. I daily drive my car, exhaust setup is 3" DP, no cat, dual 3" resonators, and an N1 muffler now and it is perfectly fine in car. A bit louder than stock cruising, on par with a quieter catback on a N/A car, like an apexi world sport.
Old Mar 29, 2005 | 09:46 AM
Pikachu's Avatar
resonators don't hurt performance right? That sounds like a good idea with the dual 3" resonators.
Old Mar 29, 2005 | 10:31 AM
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">resonators don't hurt performance right? That sounds like a good idea with the dual 3" resonators. </TD></TR></TABLE>
If they do, it's something small like just a handful of RPM. They're basically a straight through glasspack muffler that helps tone done the exhaust. Helps get rid of the buzziness, the drone, and the raspyness of your exhaust
ThatsTheTruth
Apr 25, 2006 09:57 AM
blackriceman
Apr 25, 2004 01:10 PM
HiVolume.com
Apr 24, 2004 03:02 PM
prelittlelude
Jul 30, 2003 12:10 PM
