BOV question...
Old Mar 21, 2005 | 06:28 PM
Soccerking3000's Avatar
Default BOV question...
i am running NA with everything turbo still installed except for the turbo, i have a normal header on there. Now i popped the hood and i heard noise coming from the BOV, like air was being sucked in through the port on it (its a greddy tpe-s). So the intuitive person i am i stick my finger into the hole to see if its open and it was slightly open and air was being pulled into it. Is that supposed to happen, the vacuum line is still hooked up to it as well...
Old Mar 21, 2005 | 06:53 PM
Integra21's Avatar
Default Re: BOV question... (Soccerking3000)
[QUOTE=Soccerking3000]i am running NA with everything turbo still installed except for the turbo. [QUOTE]
good luck
Old Mar 21, 2005 | 07:01 PM
Default Re: BOV question... (Integra21)
its just all the charge piping,vacuum lines et cetera, just not the turbo/mani/downpipe, but thanks for answering my question
Old Mar 21, 2005 | 07:03 PM
wantboost's Avatar
Who is Mr Robot?
yes its normal, almost all bov's leak under vacuum
Old Mar 21, 2005 | 07:10 PM
adseguy's Avatar
Default Re: BOV question... (wantboost)
yep totally normal....I'd say remove the vaccum line and plug up the vaccum line to the source. Actually NM just reinstall your stock or old Air intake system. It's easy to do and you'll get better performance before you put the turbo on. If you ever plan to
Old Mar 21, 2005 | 07:13 PM
Default Re: BOV question... (adseguy)
i had it on but took it off because i went away to college and the car was going into storage, i came home for break and just noticed it, but thanks for the info guys
Old Mar 21, 2005 | 07:55 PM
mike93eh
Guest
Posts: n/a
take the vacuum line off and plug it.
98CivicTech
Mar 10, 2009 09:16 AM
superslow-oto
Oct 27, 2007 05:34 PM
Hazymix
Apr 9, 2007 12:07 AM
KeithGSR
Jun 6, 2004 09:02 PM
egsick6
May 30, 2002 09:52 PM
