BOV problems
Old Apr 18, 2003 | 09:56 AM
Tinker219's Avatar
Default BOV problems
car: B18A 89 Civic 4dr.
setup: t3/t4 turbo, custom piping, dsm 450cc, smc+.
problem: BOV will not work.
Ive tried two BOV's neither of them work. I T'd into several different vaccum locations with both BOVs, nothing works. I even tried a factory Saab(bosch) BOV, and that wont work. What gives? I noticed Im only getting -10 on the vaccum side of the boost guage. Think the motor is shot? Runs great, pulls even greater...
Old Apr 18, 2003 | 10:08 AM
Ivan's Avatar
senior gold member
Default Re: BOV problems (Tinker219)
maybe a leak somewhere in your piping?
Old Apr 18, 2003 | 10:12 AM
Tinker219's Avatar
Default Re: BOV problems (Ivan)
how would this prevent the BOV from opening? Im no criticizing, just trying to figure this out. Im serisouly scratching my head here...
the BOVs are smooth too, not sticky or anything...
Old Apr 18, 2003 | 10:13 AM
Ivan's Avatar
senior gold member
well maybe you have anough pressure in the pipes to keep you in boost but as soon as you let off the throttle the pressure escapes thru the leak and not thru the bov. I mean I'm not saying thats the problem, I'm just saying its something to look for.
Old Apr 18, 2003 | 10:16 AM
Tinker219's Avatar
well...maybe. its a .45 bar spring, and we are seeing 4-5 psi. the IC is HUGE though, so I figured it was just pressure drop. I checked for leaks too, all tight.
Old Apr 18, 2003 | 10:17 AM
RGAZ's Avatar
New User
You have a vacuum leak. That is preventing the BOV from working. Fix the leak and the BOV will work.
Randy
Old Apr 18, 2003 | 10:18 AM
Ivan's Avatar
senior gold member
ummm thats weird then. I was having that problem once but it was my vacuum and now its all good
Old Apr 18, 2003 | 10:19 AM
Tinker219's Avatar
Hmm...I will check everything out AGAIN. im positive there are no leaks. New lines all around...
i dont know what else it could be besides vaccum though...anybody else experience this???
Old Apr 18, 2003 | 10:21 AM
Ivan's Avatar
senior gold member
what positions id you try for the vacuum?
Old Apr 18, 2003 | 10:23 AM
Tinker219's Avatar
I tried all of the ports on the back of the I.M. I tried one of the 3/8 lines on top of the mani...ount know anymore.
Its got to be vaccum related, because Im only getting -10 on the boost guage. you want around -22...
Old Apr 18, 2003 | 10:24 AM
Ivan's Avatar
senior gold member
umm I have mine on my fuel pressure. Try there and use it for only the bov and fuel and see what happens
Old Apr 18, 2003 | 10:25 AM
Tinker219's Avatar
I will do this...thanx guys...
teddy_dc2
Oct 6, 2005 07:24 PM
CRXdan
Dec 11, 2004 10:38 PM
dunkd
Apr 25, 2004 02:35 PM
DeadLock23
Nov 13, 2003 08:39 PM
Lamchop0000
Sep 11, 2002 07:34 AM
