BOV not working at all
Old Nov 1, 2006 | 01:45 PM
jsoob's Avatar
Default BOV not working at all
My HKS SSQ is not working at all, i tried relocating the vacuum source to the brake booster line and I still have nothing. It barely opens. Took it appart and tried to clean it and grease it up and nothing seems to work. I'm running 6psi right now, give me your opinions.
Old Nov 1, 2006 | 01:58 PM
turboZChatch's Avatar
Default Re: BOV not working at all (jsoob)
Is your car making the full 6psi or do you have a leak in the piping somewere? If your sure the vacuum source is sufficent(sp) you might just be expecting more noise then it is supposed to be making...are you experiencing turbo surge ie. stalling the turbo rather then blowing off the excess boost?
Old Nov 1, 2006 | 02:03 PM
jsoob's Avatar
Yes I do have a surge, bov doesn't release anything so i get a fluttering noise. Im getting a full 6psi and no problems there with it holding up.
Old Nov 1, 2006 | 02:05 PM
g2turbo's Avatar
Default Re: (jsoob)
is the bov new or used?
Old Nov 1, 2006 | 02:16 PM
jsoob's Avatar
It's used but i took it appart and cleaned it and greased it up and looks to be in really good condition inside. It just wont open up
Old Nov 1, 2006 | 02:18 PM
g2turbo's Avatar
Default Re: (jsoob)
it may be messed up, are you certain to be getting a good vacuum/boost source correct?
Has it ever worked for you?
Old Nov 1, 2006 | 02:20 PM
jsoob's Avatar
Well i bought it used and since ive hooked it up no luck. The vac source is fine it just wont blow off and its causing what sounds like a surge.
Old Nov 1, 2006 | 02:21 PM
g2turbo's Avatar
Default Re: (jsoob)
get a known good bov, and get your money back for that one lol.
Old Nov 1, 2006 | 02:25 PM
jsoob's Avatar
Yeah ive done everything, the only thing that is left is that its fuct
dturbo
Apr 11, 2006 07:03 PM
buttsneeze
Mar 17, 2005 11:07 PM
kholmes
Apr 30, 2004 01:20 PM
InTeGrA B18b1
Aug 22, 2003 01:52 PM
leadtrum
Jun 12, 2002 04:07 PM
