bov not blowing off
pretty much just what the title says. when i shift it sounds like compressor surge. one friend of mine says thats just the was your bov sounds and the other says its compressor surge. i have loosend the stud on the top of the bov all the way loose and it still does it. i have the vacume line ran to the fpr.
Setup:
jdm b16
t3/to4e 60 trim on 6 lbs
greddy type rs bov
any help would be appriciated
Setup:
jdm b16
greddy type rs bov
if it sounds like ch ch ch ch chuhhhhhh thats compressor surge. I have a vacuum manifold off of my brake booster, so i dont know what to tell ya bout vac source, I do reccomend it though I got a golden Eagle one. that way NO ?s about vacuum,ya know???
Also, I have a TIAL BOV and had to put a lighter spring in it to get rid of the surge I experienced. I run 10 PSI but the surge only happened at part boost levels though.
I have 22" vacuum at idle, and the 11psi BOV spring was too boo koo, went with a 9, now its fine.
Good luck!!!
Good luck!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo »</TD></TR><TR><TD CLASS="quote">my vacume is around the 20's at idle. mybe my spring is to stiff</TD></TR></TABLE>
I had this problem with my old BOV.. I heated up the spring and shrunk it and its been working great ever since..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Power »</TD></TR><TR><TD CLASS="quote">If you loosened it and it doesn't sound better...tighten it and see what that does. If that doesn't help, make sure you have a good vac source hooked up to it.</TD></TR></TABLE>
I did all this with my old one and it still didnt work.. Crushing the spring down was the only way.. But this is a last option after you have checked and tried everything else..
Does it have a lower vacuum port like the Type S one does? Connect that to boost pressure and you will never see surge again.
Another reason it might not be working is that you have a vacuum leak.
sup nick, its brian...has your car been idleing still?
no, his rs doenst have a lower vac port like the type s...i dont like the rs b/c ive heard of people having problems w/ it compresser surging like his
I had been playing with the HKS SSQ BOV and also had this issue. Except once the engine got warm and the BOV as well, it started to work.
I also figured out that if there is any slight vacuum leak at all, when the vacuum in the manifold goes to 26" between gears, you won't get 26" because of the leak, and the BOV won't open up. Try getting a unique Vac signal from the manifold, if it is T'd with the FPR, I find that most FPR's especially aftermarket can't seal vaccum and have a slight leak.
The problem with the spring being too loose is that you will find that the car will jerk sometimes under part throttle acceleration because the BOV is unnecesarily opening up.
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
yea that my problem tooooo man when im in boost it jerks at 6000 rpm noot trying to steal ur thread but i wanna know what should i do to prevent the bov open in boost or part idle
Spoon95, Can't do anything but crank down on the spring's preload some more and just don't boost too much when the car is cold because that BOV won't open up. It is better than the car jerking like crazy. I couldn't figure it out for the longest time until a buddy of mine pointed me to it. Check your vac lines for possible leaks too.
It feels like a misfire, I thought I was misfiring or something, but alas, it was the POS BOV.
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synapse »</TD></TR><TR><TD CLASS="quote">Spoon95, Can't do anything but crank down on the spring's preload some more and just don't boost too much when the car is cold because that BOV won't open up. It is better than the car jerking like crazy. I couldn't figure it out for the longest time until a buddy of mine pointed me to it. Check your vac lines for possible leaks too.
It feels like a misfire, I thought I was misfiring or something, but alas, it was the POS BOV.</TD></TR></TABLE>
ill check it tomorrow morning thanks for the input
hook your boost guage up to the t that is going to the bov, and check for vac. if it reads normally then you have a problem with your bov. mine was doing the same thing, i had it hooked up the the butterflies, i moved it to the fpr and now its fine, and you can definatly tell the difference!
Hoosier Daddy
Feb 15, 2004 02:45 PM
