BOV flutter
Old Aug 30, 2005 | 01:46 PM
urbansi's Avatar
Default BOV flutter
just started happening, anyone have any ideas of why this would just randomly start
Old Aug 30, 2005 | 05:43 PM
pubestripe's Avatar
Default Re: BOV flutter (urbansi)
well, it would help if u told us what kind of blow off valve u had...
Old Aug 30, 2005 | 06:06 PM
whoneedzvtec's Avatar
well this happened to me when the vaccum line that goes from ur bov to where ever u have it tapped into gets hot. if u r using one of those silicone lines or a weak vaccum line after driving for a couple of minutes it will get hot and it will suck the line together. (kinda looks like ur vaccum line is flat). it will be hard to find because if u dont open the hood soon enough, the line will go back to normal and u wont be able see any problems with it. just open ur hood while ur eng. is cold and give that line a pinch, if it is at all easy to pinch that line, that is more than likely ur problem. good luck.
Old Aug 31, 2005 | 06:03 AM
urbansi's Avatar
Default Re: BOV flutter (dc2ls-t)
the line is ok for all i can tell. anyother suggestions.
Old Aug 31, 2005 | 02:15 PM
urbansi's Avatar
ttt
Old Aug 31, 2005 | 02:21 PM
N20civicB18's Avatar
Default Re: BOV flutter (pubestripe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote">well, it would help if u told us what kind of blow off valve u had... </TD></TR></TABLE>
Old Aug 31, 2005 | 02:29 PM
urbansi's Avatar
Default Re: BOV flutter (N20civicB18)
oops, it like a knock off blitz dd. not sure of the exact brand but the design and sound are identical
Old Aug 31, 2005 | 02:33 PM
pheurton-skeurto's Avatar
very possibly the culprit of your problems. any time you buy a knock off, youre risking something. my 1st gen dsm bov sucks and is starting to do the same thing + bleed boost...
Old Aug 31, 2005 | 03:10 PM
urbansi's Avatar
Default Re: (pheurton-skeurto)
yeah i was hoping that it wasnt the problem, well the only way to tell now i guess is to get a new one. you think it will be ok to run for a few weeks until i can order a new one???
Old Aug 31, 2005 | 04:38 PM
ramennoodles's Avatar
Default Re: (urbansi)
did you try adjusting the spring tightness
Old Aug 31, 2005 | 06:36 PM
urbansi's Avatar
Default Re: (ramennoodles)
yeah i did it tonite but with no luck, but anyways does anyone know if it is harmful to the turbo if this is happening
here is the BOV
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Aug 31, 2005 | 08:59 PM
pubestripe's Avatar
i think that the problem is that that is a **** BOV... get a new one if the adjustment isnt helping. is your psi fluctuating more too?
Old Aug 31, 2005 | 09:46 PM
jayswift's Avatar
what kind of waste gate do you have? if you have an acutator type, check the vacuum line to it. when i tightened the line too much on the actuator it left a small crack and it caused the BOV to sound like that no matter how much i adjusted it.
Old Aug 31, 2005 | 10:24 PM
Default Re: (jayswift)
I'm running the real Blitz bov and it flutters in normal driving(little boost pressure) and doesn't flutter under hard driving(over 5psi boost)
Old Sep 1, 2005 | 09:50 AM
pubestripe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramennoodles &raquo;</TD></TR><TR><TD CLASS="quote">I'm running the real Blitz bov and it flutters in normal driving(little boost pressure) and doesn't flutter under hard driving(over 5psi boost)</TD></TR></TABLE>
yeah i have rode in a car with one and it does the same.. but i really think it comes down to how shitty the BOV is...
Old Sep 3, 2005 | 02:32 PM
urbansi's Avatar
Default Re: (pubestripe)
well now it feels like the car is losing power, i wounder if the BOV is now leaking boost. i guess i am going to have to wait and see once i get home. any other opinions would be helpful
Old Sep 3, 2005 | 04:02 PM
it wouldn't hurt to take it apart and check for damage. also to put a little lube on the seals
Old Sep 3, 2005 | 04:41 PM
urbansi's Avatar
him, ok i am going to have to try that once i get home, it really sucks that when i bought it i had know idea that is was made by XS so this time if its actually broken i think i am just going to buy the GReddy type S.
as for the sound of the BOV it fluttered at low boost also but under high boost like anthing over 7psi or so it sounded exactly like a Blitz DD. you can here it on my dyno video below
Old Sep 3, 2005 | 08:26 PM
SL0WEGG's Avatar
maybe theres not enough vacuum to let the bov release pressure. what your hearing isnt the bov fluttering. its actually called compressor surge which means the air has no where to go when you let off the gas so it goes back to the turbo and try's to push it the opposite direction making that odd fluttering noise. my 1st gen dsm one did that only because my vac line to it was pinched.
Old Sep 3, 2005 | 09:36 PM
pubestripe's Avatar
Default Re: (boostedej1)
yeah and that compressor surge is not to good for the turbo...
Old Sep 4, 2005 | 08:21 AM
rhd's Avatar
rhd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote">yeah and that compressor surge is not to good for the turbo... </TD></TR></TABLE>
have you ever heard of a turbo actually breaking due to compressor surge? highly doubt it.
but the bov shouldn't be the problem...all the ebay knock offs work just as good as "the real thing"
you either have a collapsed line, it's tightned TOO much, or it's working properly and you just dont realize it.
Old Sep 4, 2005 | 08:34 AM
asilaydying1984's Avatar
i have a xs blow off valve i will sell you i dont know what the name of it is but i will sell it for 60 shipped
Old Sep 4, 2005 | 09:47 AM
urbansi's Avatar
Default Re: (asilaydying1984)
yeah well i know all about XS and SSAC but io didnt buy it on purpose, the kid i bought it off of ripped me off, which i now realize cuz like a year ago i gave him $100 for it. well if i had known what product i was buying i would have not bought it . so i am going to take off the BOV and check it, i think maybe a line may have gotten pinched when i replaced my fuel filter or when i replaced the distibuter cap the other week cuz that now is the only thing i can think of
:me calling my self a dumb ***:
so hopefully i will have this problem solved by the end of tonight
Old Sep 5, 2005 | 01:27 PM
urbansi's Avatar
well i looked over my vac lines and everything seems to be ok with them, i removed the one on the BOV and nothing seems out of the ordinary. didnt have time to remove the BOV itself but i am now leaning towards the BOV a little more.
anyone have anyother ideas???
Old Sep 5, 2005 | 02:37 PM
pubestripe's Avatar
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">
you either have a collapsed line, it's tightned TOO much, or it's working properly and you just dont realize it.</TD></TR></TABLE>
would you want to put any unnecessary wear and tear on the turbo??? i dont think so...
