Bosch injector fitment
Old Feb 15, 2002 | 08:08 PM
Darin D.'s Avatar
Default Bosch injector fitment
I recently purchased bosch 50 lbs injectors (550cc). The guy I bought them from said that the fuel rail needed slight modification but he didn't know exactly what to do. So I tried installing them tonight and they fit nicely in the lower bushings, but the top o ring barely slides up into the fuel rail hole enough to seal. So my question to anyone that has used these is, do I enlarge the holes in the rail and use the large o rings that came with the injectors or, should i shave down the plastic on the injector that keeps it from sliding into the rail and use the stock o rings?
I actually got it running with no leaks by just using washers to space the rail up but im worried that it will start to leak because the o ring just barely slides into the hole.
any information about this would be greatly appreciated.
Old Feb 16, 2002 | 01:16 AM
dustin's Avatar
Default Re: Bosch injector fitment (Willis)
Post some pics, I am interested.
Old Feb 16, 2002 | 02:29 AM
d mafia's Avatar
New User
this sounds similar to my MSD injectors. I just shaved down the plastic bushing and used a smaller O-Ring on my MSD. Did not modify the fail.
10sec4door
Jul 11, 2010 08:46 AM
slow poke
Dec 1, 2007 06:13 AM
Ronin150
Jul 18, 2005 01:40 PM
ThePro
Jun 16, 2005 08:58 PM
Ek00fbp
Dec 2, 2003 09:46 AM
