Bosch / Endyn intake pump HP limits
Old May 15, 2005 | 09:57 PM
CRVRX's Avatar
Default Bosch / Endyn intake pump HP limits
Anybody had any comments using this intank pump with a larger feed line. I don't want to run a sump and a areomotive pump and all the junk that goes with it .
I know they rate the pumps to I think 750 hp, or somewhere around there.
Thanks.
Old May 16, 2005 | 04:14 AM
CRVRX's Avatar
Default Re: Bosch / Endyn intake pump HP limits (CRVRX)
Anybody used this pump ?
Thanks.
Old May 16, 2005 | 12:13 PM
CRVRX's Avatar
No one used this pump ?
Old May 16, 2005 | 12:15 PM
dennis's Avatar
It's definitely not as popular as the walbro counterparts, but I'd just give Larry at endyn a call and ask him.
Old May 16, 2005 | 12:31 PM
CRVRX's Avatar
Default Re: Bosch / Endyn intake pump HP limits (dennis)
I would call Larry, But I think he would tell me anything I want to hear.
I have done over 500whp on a walboro pumps , I just want a pump that will fit in the tank that would support a little more with some larger fuel line.
Old May 16, 2005 | 12:33 PM
servion's Avatar
The pump is supposed to support at least 700whp.... but endyn no longer modifies them to fit in the stock tank. They will sell you one but you'll have to run it outside of the tank.
Old May 16, 2005 | 12:34 PM
CRVRX's Avatar
Default Re: (servion)
Thanks,
I have access to the pumps and I can modify it to fit in the tank, just want to see if it really will hold 600+.
Any other intank pump options ?
Old May 16, 2005 | 12:48 PM
servion's Avatar
I think that's the best you'll get if you're stying intank... curious, what kind of deals can you get on that pump?
Old May 16, 2005 | 01:01 PM
CRVRX's Avatar
I'll find out and post up the price . I really don't want to add a sump etc...
Old May 17, 2005 | 06:08 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">The pump is supposed to support at least 700whp.... but Endyn no longer modifies them to fit in the stock tank. They will sell you one but you'll have to run it outside of the tank.</TD></TR></TABLE>
Even when they did modify the pump to fit in the tank it still required ALLOT of work to get it to fit. That’s why they stopped screwing with them.
The internal working of the tank have to be modified with a BFH and the hole on top of the tank has to be re shaped along with the cover and you would have to make your own seal and make sure it worked (sealed properly).
Its a big PITA and not many have the skills to do the tank modification.
Old May 17, 2005 | 08:37 AM
servion's Avatar
Default Re: (White Smoke)
That's pretty much exactly what endyn told me in an email when I asked about that probably 4-5 month ago
Old May 17, 2005 | 01:27 PM
CRVRX's Avatar
Thanks for the relpys..
What options of pumps are they without building a sump. Is there a pump that deosn't require to be gravity fed ? Meaning , replacing the pump with a tube and a sock ( Like the stock postion ) on the bottom and have an inline pump pulling the fuel out the tank?
Thanks.
Old May 17, 2005 | 01:49 PM
Sonny's Avatar
John,
If you want to erase all doubts, send that pump to RC Engineering and have them flow test it. The numbers for the Walbro stuff are readily available from RC, so if you test that one, you'll have the answers you're looking for.
Sonny
ohsnapzafingcu
Nov 17, 2013 08:20 PM
ShawnR
Mar 31, 2007 06:46 PM
CRVRX
Jul 27, 2002 10:00 PM
veejay
Jul 22, 2001 10:57 AM
