boring and turbo question
Old Sep 5, 2007 | 12:53 PM
blakh's Avatar
Default boring and turbo question
im going to be boring my b16 to 83mm and i plan on turbo in the future, and i am just not sure if should get it sleeved or not. what would you recomend, my goal is to have atleast 400whp in the end. im not sure if that helps but i thought i would say that just incase it makes a differnce.
Old Sep 5, 2007 | 02:16 PM
blakh's Avatar
Default Re: boring and turbo question (blakh)
plz advice?
Old Sep 5, 2007 | 02:18 PM
redlinetuning's Avatar
on a b16, i wouldn't recommend boring your stock sleeves to 83mm. The walls will be too thin and crack under pressure, especially if you're expecting to push 400whp.
Old Sep 5, 2007 | 02:26 PM
blakh's Avatar
ok. so get it resleeved? or will that not make a differnce
Old Sep 5, 2007 | 02:43 PM
ABK's Avatar
ABK
just don't bore it to 83mm. I would just bore it to 81.5mm. Good set of pistons and rods, with a good setup even on the stock head you should be able to hit over 400whp if you push enough boost thru it.
Old Sep 5, 2007 | 02:45 PM
blakh's Avatar
ya, i baught pistons that are 83mm they were listed as b16 81mm pistons on ebay baught em for 270 nib and was surprised when they came then to my surprise his ebay account was deleted./
Old Sep 5, 2007 | 02:57 PM
blakh's Avatar
so bad idea to keep em and boost with them..
Old Sep 5, 2007 | 03:07 PM
Schister66's Avatar
Man U FTW
Default Re: boring and turbo question (redlinetuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning &raquo;</TD></TR><TR><TD CLASS="quote"> i wouldn't recommend boring your stock sleeves to 83mm. </TD></TR></TABLE>
is that even possible??? The only way to EVER put 83mm pistons in your B series w/ boost is through aftermarket sleeving...although i'm sure that's been said already
Old Sep 5, 2007 | 03:14 PM
ABK's Avatar
ABK
Default Re: boring and turbo question (Schister66)
I might be wrong but I think few people done it on all motor setups. I wouldn't go past 81.5, some people do 82mm on stock sleeves but they can crank even without any type of forced induction.
Old Sep 5, 2007 | 03:24 PM
blakh's Avatar
alright. i guess they are going up for sale :-/
my luck... :-(
maybe ill just buy another block and throw these in this while building the other.... idk if its worth it though. hmm
HiProfile
Nov 26, 2009 07:02 PM
912
Jul 9, 2009 05:32 PM
lovey408
Apr 9, 2007 09:46 PM
bumsta217
Sep 10, 2005 12:57 PM
