boosting a stock b16
Old Jul 20, 2004 | 09:45 AM
  #26
HyperITR742's Avatar
Default Re: (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">bone stock JDM B16 boosting 5 pounds, SC61E 69 trim, stock injectors and ECU, no tuning of any kind. Plan on making 350 on pump gas and stock motor, hopefully on 12 pounds</TD></TR></TABLE>
Thats a bit high..especially if you plan on keeping that motor for more than a week. Good luck though
Old Jul 20, 2004 | 10:01 AM
  #27
DigitalFusion's Avatar
Default Re: (-TRINiTRON-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- &raquo;</TD></TR><TR><TD CLASS="quote">using the stock manifold would put the turbo way too low. You would never get positive flow from your return line to the oil pan. Just get a manifold...skimping out only casues headaches and more money later. Just save your cash and do it right. You will be happier in the long run. </TD></TR></TABLE>
what he said
Old Jul 20, 2004 | 10:07 AM
  #28
RobbieG35's Avatar
12 Years Strong
Default Re: (HyperITR742)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyperITR742 &raquo;</TD></TR><TR><TD CLASS="quote">
Thats a bit high..especially if you plan on keeping that motor for more than a week. Good luck though </TD></TR></TABLE>
There are lots of cars making way over 350 on stock motors, its nothing that has not been done before, with a good tune it should be no problem
Old Jul 20, 2004 | 10:55 AM
  #29
Nate047's Avatar
Sure they make the power, but they blow the **** up in like a week or two... Is that really worth it to you? For me it sure is'nt.
Old Jul 20, 2004 | 11:05 AM
  #30
There are lots of cars making way over 350 on stock motors, its nothing that has not been done before, with a good tune it should be no problem</TD></TR></TABLE>
Thats too much power for the little 1.6. I don't want to discourage you, but thats not going to happen. Even if it does, it won't be alive for long
Old Jul 20, 2004 | 11:07 AM
  #31
raene's Avatar
Default Re: boosting a stock b16 (PHOBIA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">i dont mean to rev it up that high,its just when mr.mustang is setting next to me thinking he is bad *** with his little botfriend and throws a rev i throw one back,i sometimes just hold it a little to long,and its to late by the time i realize it.what causes it to smoke?the grey smoke anyways i was told that it means the rings are shot.i always thought it was a head gasket.what kind of tuning is available on an obd0 b16? ok so the rods are plenty strong then and i wont worry about changing it out until later.</TD></TR></TABLE>
I take it to 8800 regularly on stock valvetrain, no problems yet Leakdown below 5% on all cylinders and over 210 compression all around. Hell, I launch at 7500+ rpm.
Old Jul 20, 2004 | 02:25 PM
  #32
PHOBIA's Avatar
i measured the top of the exhaust manifold to the newly pressed studs amd from tip to tip it it 9 3/8 long .how low does a turbo usually sit with a drag manifold?
b16eh2
Nov 10, 2014 07:48 AM
redflaredcrx90
Sep 8, 2009 05:41 PM
honda_mike
Oct 29, 2008 10:46 AM
harker
Jun 12, 2008 12:33 PM
nboost
Mar 21, 2006 06:39 PM
