boosting a sohc - cathcan setup needed?
Old Feb 9, 2006 | 12:33 PM
AbitAvenger's Avatar
Default boosting a sohc - cathcan setup needed?
Okay I am going to boost my d16z6 pretty soon and I was wondering what I would need to do, if anything with the pcv setup. I should also add that I really don't even know what the pcv system does. I'm only boosting 9 lbs if that matters.
Old Feb 9, 2006 | 02:01 PM
Anybody have any real life experience? Could I boost it and just leave it the way it is (stock)?
Old Feb 9, 2006 | 04:47 PM
eastbay92cx's Avatar
Default Re: (AbitAvenger)
put a breather filter on the valve cover and route a line from the stock baffle tank on the back of the block to a slash cut in the exhaust (after cat if you have one) to suck out vapors and relieve pressure on the crankcase. or you could route the baffle tank to a tube in the intake before the turbo, this is emissions friendly. Doing this is beneficial, helps with oil consumption, gives (perhaps negligible) better performance. Some 3/8" hose should stuff into the stock breather tank, it's pretty easy.
At minimum, you'd probably want to disconnect the line going from the intake manifold to the crankcase (w/ pcv valve).
Old Feb 10, 2006 | 11:04 AM
Good info thanks, anyone else?
Old Feb 10, 2006 | 11:09 AM
beerbongskickass's Avatar
I have been boosted for 2 years and haven't ran a catch can setup.
Old Feb 10, 2006 | 12:09 PM
nerdsports's Avatar
ive been boosted for nearly 3 years and have always had the PCV system in place.
i have put a catchcan in between the intake manifold and the pcv valve to collect oil before.
the PCV is essentially a check valve, no positive pressure will enter the crankcase. but you do want pressure to escape from the crankcase... especially in boost.
you can do like eastbay92cx said, but a. oil getting into your exhaust will create the bluish-white smoke we hate seeing and b. oil will get into your compressor housing/charge pipes/IC. also not a good thing.
if you do either of those, put a baffled catchcan inline to collect oil before entering exhaust or turbo intake.
Old Feb 10, 2006 | 01:15 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">I have been boosted for 2 years and haven't ran a catch can setup.</TD></TR></TABLE>
So you're running an OEM, PCV-in-stock-location, hose from the valve cover to intake setup?
eluder33
Mar 24, 2005 11:19 AM
igo4bmx
Aug 18, 2004 06:55 AM
Ek00fbp
Nov 26, 2003 04:45 PM
yellowturbo
Sep 22, 2003 01:46 AM
Ri5e
Aug 12, 2002 09:53 PM
