Boosting issues
Old May 28, 2011 | 12:05 PM
guy_from_nerk's Avatar
Default Boosting issues
I have a 6lb spring in the gate (precision 46mm) there is 3 ports on the gate. The top 1 is supposed to be left open if boost controller isn't hooked up. So we left that open. Now the other 2 ports is what were having an issue with. If we leave one of the side ports opened the car will hit 9psi (thats where boost cut is set at), if we plug both ports it will only hit 3.3psi
Any ideas what the issue is here, precisions instruction manual is nice but doesn't go into details as to which port if any needs to be plugged
Old May 28, 2011 | 12:38 PM
turbohatch96y7's Avatar
Default Re: Boosting issues
Do you have a boost controller hokked up if not then leave all the ports open and you should hit the spring pressure
Old May 29, 2011 | 06:25 AM
we got the boost issue solved, car now hits and holds 6psi just fine.
Old May 29, 2011 | 02:38 PM
What was the issue?
Old May 31, 2011 | 11:36 AM
Couldn't even tell ya lol, it just started working out of the blue and hasn't had any issues so far...really weird
94turboeg
Aug 13, 2007 12:08 AM
rickturboteg
Aug 28, 2006 05:36 PM
all go teg
Aug 5, 2005 04:56 AM
pip9
Sep 24, 2004 09:17 AM
accordfreak
Dec 25, 2001 12:20 AM
