Boosting a B16b?
Old Mar 23, 2003 | 06:08 PM
cvclover's Avatar
Default Boosting a B16b?
Is it a good idea to boost a b16b CTR motor with a turbo? Any precautions?
Old Mar 23, 2003 | 06:13 PM
shermanyang's Avatar
Default Re: Boosting a B16b? (cvclover)
Umm...I'm assuming you mean LS/Vtec motor right? If so, yes it's a good idea...you'll just have to fix up the oil lines so there's enough oil going to the head while there is also enough flowing to the turbo. It's not that hard.
Old Mar 24, 2003 | 05:46 AM
cvclover's Avatar
Default Re: Boosting a B16b? (shermanyang)
I didnt think the b16b was a ls/vtec. Isnt that the b18b? I'm talkin bout the Civic Type R engine.
Old Mar 24, 2003 | 06:27 AM
madman13lm's Avatar
Umm... From what I understand you couldnt do that much boost due to the high compression of the motor, in which case you would need to lower the compression ratio for higher boost. If you plan to build the engine to handle a lot of boost, you might as well go with a cheaper engine, like the B16a. I think the B16b's head is the same as the ITR, but I dont know if that would be worth the extra cost of the engine. Just something to think about.
Old Mar 24, 2003 | 06:41 AM
RyanEJ8's Avatar
Default Re: Boosting a B16b? (madman13lm)
I think the B16B head has the same casting as the B16A head just different internals.
iverson3yoo
10
Feb 15, 2010 03:59 AM
trytomake
Aug 15, 2009 03:09 PM
poormans_typer69
Jul 22, 2008 03:07 PM
jdm-cd5
Jun 23, 2007 05:33 PM
theoriginaljmft
Sep 26, 2006 05:54 PM
