Boostin on 168k
Old Mar 7, 2006 | 10:06 PM
ex94vtec's Avatar
Default Boostin on 168k
My 1994 civic ex has 168k on it...I bought it last november from the original owner with 162k. as far as i know it was never beat on. At the time i got it it was being drivin by the owners 75 year old father. I have pieced together a turbokit around a turbonetics T3. I recently did a compression test and these were the results.
179
175
171
168
Question is will i be able to run about 7psi on this engine safely with the proper tuning?
Old Mar 7, 2006 | 11:41 PM
94hatchling's Avatar
Default Re: Boostin on 168k (ex94vtec)
those numbers are pretty good considering the mileage. only thing that concerns me a little is the difference between cylinder 1 and 4. over 10psi difference.
boosting what you have will make it wear much quicker since it is already in that stage. but with proper tuning, it should run pretty reliably.
have a buddy that ran nitrous on his si for about 40,000 miles, then boosted it at 120,000 miles. it ran strong and very reliably. anything could happen, but sounds good. go for it.
Old Mar 8, 2006 | 01:47 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Boostin on 168k (94hatchling)
you should be ok, d series are a dime and dozen.
just make sure you aren't overboosting suck as when it spikes at high rpms
Old Mar 8, 2006 | 03:38 AM
wilsel's Avatar
Default Re: Boostin on 168k (MugenHonda)
7PSI, proper tuning, w/ regular oil changes and it should last a long time.
Old Mar 8, 2006 | 03:41 AM
The_Todd's Avatar
Farts in the shower
I would personally retest compression.
But boost it and in the mean time build a spare d .
Old Mar 8, 2006 | 06:13 AM
sohc'd upEJ8's Avatar
Default Re: Boostin on 168k (.ken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">I would personally retest compression.
But boost it and in the mean time build a spare d .</TD></TR></TABLE>
shahriar35
Aug 22, 2017 04:38 PM
ex94vtec
Mar 7, 2006 10:30 PM
James
Jan 5, 2004 10:50 AM
boostdGS
May 7, 2003 07:10 AM
spladam02
11
Nov 29, 2002 02:37 AM
