Compression too high?
I've got a 98 gs with 87k miles, and i run 8 psi daily. I went to my shop yesterday to get a compression test done. To me, my numbers look a bit high, and I'm wondering if my shop is bs-ing me.
205 psi cyl 1, 200 psi cyl 2, 200 psi cyl3, 205 psi cyl 4
I run 8 psi daily with zero problems. My engine runs really great, and I baby it all the time, so I didn't think the numbers would come back bad, but I didn't expect them to come back higher than nominal. Any input's appreciated.
If you don't believe them, you could always compression check it yourself. Compression testers are not that expensive, and it is by no means a hard test to perform.
brent_G
Oct 12, 2003 12:15 AM
