...BOOSTED D-SERIES HELP...
Old Oct 17, 2011 | 08:54 AM
js97f22b's Avatar
Default ...BOOSTED D-SERIES HELP...
hey guys looking to boost a d16 to around 17 pounds would like to know what needs to be done to the motor, upper/lower end etc. i planned on eagle h beam rods, vitara pistons, arp headstuds, sleeves, balance crankshaft. would like something pretty reliable not sure if this is all necessary??? what about the head should i build it??? any thing else im missing?? suggestions and any help would be greatly aprreciated, thanks
Old Oct 17, 2011 | 09:47 AM
xXSanderXx's Avatar
Default Re: ...BOOSTED D-SERIES HELP...
Search, there is alot information on this forum.
But first question, what's your hp goal?
Old Oct 17, 2011 | 09:52 AM
grumblemarc's Avatar
The Grumpiest
What are you missing? Everything. Where did you pull 17PSI out of?
Old Oct 17, 2011 | 02:17 PM
myallmotoreg's Avatar
17psi does not tell us a whole lot. If you could give us the CFM of your turbo or just your overall hp goal, Everyone would be able to help you more.
Old Oct 17, 2011 | 03:02 PM
Hidenplanvew's Avatar
I would do FJ rods, vitaras.. eagles give you like 7.5:1 compression ratio... fj are like 8.8... other then that a P&P will help but your head and supertech valve springs with stock retainers... stock cam is the best on the street
stock sleeves are fine and the crank is fine by its self
Old Oct 17, 2011 | 07:20 PM
phat00civic's Avatar
Ditto!
Layzboy713
Nov 13, 2014 01:55 PM
funintheteg3
Mar 1, 2010 06:49 AM
hdrider
Aug 9, 2009 07:11 AM
hondaluver12
Jan 26, 2009 04:32 PM
nichols_si
Sep 8, 2006 11:58 PM
