Boosted b18c1 help
Hi so I’m building a b18c1 out of my 98 gsr, my bearing clearances are good my bore taper is good and the egging to the bore isn’t too extreme piston rings are perfect piston to wall clearence is good and I have a rod bolt stretch gauge to measure myself. All those measurements and clearences are good is there’s any others clearences I should be aware of?(on the block) I know piston to valve clearence but anything in the crank? All I did was bearing clearence on the crank am I missing anything? I want a reliable 500hp b series, it has skunk2 rods wise I pistons stock crank acl bearings skunk 2 valves springs retainers and blox racing stage 3 cams w new rockers, thanks
I have neither a sleeved block or css and I’m not gonna run a block guard, I’ve heard it will hold 500hp without either maybe I’m wrong?
I think that without much driving pressure and without a lot of useless low rpm torque the stock sleeves will be ok for 450 whp. IMO use a large turbo for 700-800 hp, good 9.5:1 forged Pistons, stronger rods and low pressure (10psi) and everything will go well. Don't forget to measure the piston ring gap and do nice honing before installing the new pistons.
caspers_hatch
Mar 20, 2005 07:52 PM
turbosi03
Aug 6, 2004 10:35 AM
