Boosted B18b Recently Dying. Need help PLEASE!!
Old Nov 1, 2005 | 02:50 PM
integranator's Avatar
Default Boosted B18b Recently Dying. Need help PLEASE!!
Hey guys--- Background:
Stock Boosted b18b
t25 14psi (safe tune s200 for about 3months)
Just recently after a pull, the car stuttered, then died and wouldn't start up.
Took it back to the shop, pulled the plugs-- looked great.
Did a compression check-- Looked great.
Checked for Spark, looked awsome.
Tried to start the car, and it does and runs fine. On the way home-- about 45mins later, the car starts doing the whole stuttering symptoms, then turns off, and won't start. Next day, car started up, then about 3 miles down the road-- same thing. Finally take it back to the shop-- thinking its a bad Pump--- check the resistance-- fine. Check all the injectors for resistance-- also fine. I'm banging my head against the wall trying to find out what the problem is-- i need my car to be safe to drive again!!
Thanks guys-- I appreciate it.
Old Nov 1, 2005 | 03:04 PM
Default Re: Boosted B18b Recently Dying. Need help PLEASE!! (integranator)
Also, in cyl. #4, when i pulled the plug, there was some oil on it. Problem?
Old Nov 1, 2005 | 04:58 PM
xenocron's Avatar
Try a different ECU?
Old Nov 1, 2005 | 05:09 PM
LVB18Civic's Avatar
Check your main relay.
Old Nov 1, 2005 | 05:23 PM
SOHC_MShue's Avatar
maybe something in your ignition is dying
Old Nov 1, 2005 | 05:33 PM
project dc2's Avatar
Default Re: Boosted B18b Recently Dying. Need help PLEASE!! (LVB18Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVB18Civic &raquo;</TD></TR><TR><TD CLASS="quote">Check your main relay.</TD></TR></TABLE>
ditto .. ill put money its the relay
Old Nov 1, 2005 | 06:40 PM
The main relay would cause the car to stutter and die when it gets heated up enough??
Old Nov 2, 2005 | 05:31 AM
up. anyone else??
Old Nov 2, 2005 | 06:18 AM
turbotime's Avatar
oil in the cylinder or oil in the spark plug tube?
Old Nov 2, 2005 | 06:30 AM
i think a little of both.
Old Nov 2, 2005 | 08:41 AM
Squirtle's Avatar
Main relay
Old Nov 2, 2005 | 12:50 PM
alright guys, swapped in a new one--- any way to check to see if the old one really was the cause??
Old Nov 2, 2005 | 03:24 PM
19sec beast's Avatar
Did the new one fix the problem? If so, then the old one was bad.
Old Nov 2, 2005 | 04:36 PM
LVB18Civic's Avatar
Default Re: Boosted B18b Recently Dying. Need help PLEASE!! (19sec beast)
If you pull the relay apart look for cracks in the solder. Usually when the solder cracks it loses connection, thus causing a no start condition.
Old Nov 3, 2005 | 05:47 AM
UGH. didn't seem to fix it. Dizzy problems???
Old Nov 3, 2005 | 07:28 AM
VTC_CiViC's Avatar
If not the relay, I'd bet the coil is going out..
Old Nov 4, 2005 | 07:52 AM
Default Re: Boosted B18b Recently Dying. Need help PLEASE!! (VTC_CiViC)
Going to replace the dizzy today, if that doesn't work... iguess I'll replace the ecu!!??!
Also, the car drives normal, until you beat on it a bit-- then thats when it decides to freak out. Any ideas?
b18egdx
Jul 31, 2006 04:32 PM
kwyjibo
Feb 9, 2005 10:16 AM
b18c195
Apr 21, 2003 06:40 PM
SIK IN DA HED
Nov 13, 2002 12:51 PM
