boost/vacumm affected by healights
Old Feb 15, 2003 | 03:41 PM
TurboedGSR's Avatar
Default boost/vacumm affected by healights
My vacum stays between 19-21in hg normally depending on the weather but everytime i turn on my headlights it comes down almost two points (usually to 18). is this normal? I really dont see how/why this could happen given its a mechanical gauge.
also how the f**k do you spell vacum/vaccum/vacumm, doesnt look right
Old Feb 15, 2003 | 03:53 PM
DeepSi's Avatar
Default Re: boost/vacumm affected by healights (TurboedGSR)
vac·u·um (vky-m, -ym, -ym)
[Modified by DeepSi, 4:55 PM 2/15/2003]
Old Feb 15, 2003 | 04:49 PM
b16ahybrid's Avatar
mine does the same....usual
Old Feb 16, 2003 | 04:18 PM
TurboedGSR's Avatar
Default Re: boost/vacumm affected by healights (b16ahybrid)
so its not just me. why/what could cause this though. engine not propertly gounded, bad alternator?
Old Feb 16, 2003 | 04:52 PM
b16ahybrid's Avatar
load on the engine....causes a voltage drop.......
same thing happens if you step on the brake...lights dim for a second....
the load drops the engines rpm a tad causing the vacuum to drop.....
btw it's spelled v a c u u m.........
grizzled
Jul 9, 2006 09:46 PM
Gsr_Hybrid_theory
Feb 7, 2005 04:38 PM
DXturbo
Jul 18, 2003 09:14 AM
lildrgn2.0
Feb 25, 2003 07:30 AM
b18tdelsol
May 18, 2002 11:46 AM
