Boost tap location???
Old Oct 10, 2012 | 07:25 PM
spoolin_crx_'s Avatar
Default Boost tap location???
Where do yall guys think the best place to put the boost guage line at? Do i tap the intake mani? If so where at?
Old Oct 10, 2012 | 07:37 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Boost tap location???
intake manifold after the throttle body....
Old Oct 11, 2012 | 04:01 AM
Okay thanks....any idea where to tap it at?
Old Oct 11, 2012 | 08:05 AM
turbohatch96y7's Avatar
Take the manifold off and drill and tap a hole.
Or you can make a T off the brake booster before the ccheck valve.
If it were me I would do the first method.
Old Oct 11, 2012 | 08:31 AM
boosted_D's Avatar
save yourself the work....
tap brake booster line before the check valve for both the blow off valve and boost gauge.
wastegate should be tapped from the charge pipes (anywhere on them or the compressor outlet)
Done.
Old Oct 11, 2012 | 08:44 AM
Yea I would try the second one...I need to get a t fitting now
Old Oct 14, 2012 | 02:01 PM
I went ahead and tapped the intake mani on the back closer to the driver side
Old Nov 28, 2012 | 08:20 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
So are the check valves Mandatory for turbo motors? I can't find one to buy at autozone/ o'reillys. All i find in the vacuum/PCV section are inline filter looking valves. Nothing says "check valve" or anything..
So cliffs: i'm boosting motor, currently no check valve. Why's it needed.. Do i need it? and WTF do i search for at the part store?
Old Nov 29, 2012 | 06:48 AM
kyden's Avatar
you don't need to buy a check valve, it's the one in the line for the brake booster. you need to tap before that valve, as you don't want to pressurize your booster.
Old Nov 29, 2012 | 12:19 PM
MalcolmV8's Avatar
I just put a couple Ts in the vacuum line between the intake manifold and the pressure regulator. One to boost gauge and the other to BOV. Works great. You can actually see it quite well in this pic
Old Nov 29, 2012 | 07:50 PM
my car didn't come with a check valve.. went ahead and bought one today and rigged it up
cheeesboiger
Jun 20, 2011 09:30 AM
lurkin' eg
Oct 19, 2008 04:28 AM
vtecteg2008
Sep 9, 2008 08:17 PM
aalb1
Oct 22, 2004 07:06 AM
B18EG6
Aug 27, 2003 02:52 PM
