vacuum hose routing help.
Old Sep 8, 2008 | 07:03 PM
vtecteg2008's Avatar
Default help please!!!....
I've just purchased a B16 integra turbo and I'm trying to get the vacuum lines straight can any one give me some advice on how I can go about routing my vacuum lines???.....
Old Sep 9, 2008 | 05:12 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: help please!!!.... (vtecteg2008)
which lines?
boost controller or no?
Old Sep 9, 2008 | 05:34 AM
totsie7944's Avatar
Default Re: help please!!!.... (boostedcivicsir)
Yea it would help to know which lines you are talking about. However, as a general rule of thumb I usually run a vaccuum block (ie Full-Race sells one) that you can hook up the brake booster to, and then a big line from the intake manifold for your vaccuum...and then you should still have 5 ports left to hook up all your vaccuum lines from your wastegate, BOV, fpr, boost controller, etc
Old Sep 9, 2008 | 01:50 PM
no boost controller.
Old Sep 9, 2008 | 02:34 PM
thatblkguy's Avatar
which lines?
Old Sep 9, 2008 | 07:53 PM
Schister66's Avatar
Man U FTW
Here's how my old setup worked. This should give you a pretty good idea of what to shoot for...
Old Sep 9, 2008 | 08:14 PM
95dxsir2's Avatar
Default Re: (Schister66)
whats the backflow valve?
one way check valve?
Old Sep 9, 2008 | 08:16 PM
Schister66's Avatar
Man U FTW
The "backflow valve" is the one-way check valve in the vacuum line from the manifold to the brake booster. Without it you would feed pressurized air into your braking system effectively taking away your ability to brake under boost. Its not the end of the world, but its a problem i'd rather avoid. BTW, it comes stock on Hondas...leave it there
Old Sep 9, 2008 | 08:17 PM
95dxsir2's Avatar
thats what i thought, thanks
mr.nguyen
Jul 9, 2009 12:15 PM
South Bay Surfer
Jul 5, 2008 06:34 PM
FyReo3
Aug 6, 2005 04:35 PM
ebpcivicsi1234
Feb 11, 2005 06:12 AM
red_sir
Feb 4, 2003 06:50 PM
