boost problems
Old Jun 8, 2003 | 08:31 PM
Rev2 9K's Avatar
Default boost problems
I just installed my T3 turbo. I am using a AFC, msd BTM, dsm 450 cc injectors w/resistor box, modified starion intercooler, turbo XS BOV and SBC. When boosting in 1 and 2 gear, the car stumbles about 6000 rpm. I replaced the plugs with a 2 step colder plugs, but it still does it. It does not do it in any other gear, just 1 and 2 gear? Anyone got Ideals.
Old Jun 8, 2003 | 08:54 PM
98civicEX's Avatar
Default Re: boost problems (Rev2 9K)
what are your settings w/ the AFC?
Old Jun 9, 2003 | 04:17 PM
Rev2 9K's Avatar
Default Re: boost problems (98civicEX)
1000 / -24
2000/ -30
3000/ -36
4000/ -37
5000/ -37
6000/ -34
7000/ -37
Old Jun 9, 2003 | 04:24 PM
95c1v1cs1's Avatar
why does it get leaner as you go up? If anything, people usually do it the other way.
Old Jun 9, 2003 | 04:46 PM
dirtySOHC's's Avatar
Default Re: boost problems (95c1v1cs1)
i dont see how in the **** ppl set their 1k at -25 or more.
and yes richer as you get higher in the RPM's
wat is your btm set at? i had that problem when i first installed my BTM. i have to run 1 degree of retard at the distributer and about .3 on the BTM. took me forever to figure it out. i was gonna rip the **** out and trash it...........i was so pissed
i wanna say its probably the BTM.......keep playing with your BTM and AFC settings
Old Jun 9, 2003 | 06:36 PM
Rev2 9K's Avatar
Default Re: boost problems (dirtySOHC's)
SO, on the **** for the btm, you have it pointing at 3, if I am correct.
Old Jun 9, 2003 | 07:52 PM
no
POINT 3, (.)3, a little less than half a degree
if you had ythe BTM at 3 degree retard you would bog like crazy, you wouldnt even be able to boost for half a second
Old Jun 9, 2003 | 08:35 PM
Rev2 9K's Avatar
Thanks bud, I am new to the turbo world. I aways been using bottle power.
What do you have your btm set at, I mean at what pouund of boost is it set at start retarding the timing.
Old Jun 9, 2003 | 10:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC's &raquo;</TD></TR><TR><TD CLASS="quote">i have to run 1 degree of retard at the distributer and about .3 on the BTM. </TD></TR></TABLE>
afrothunda713
Oct 9, 2004 09:27 AM
Slammd Sol
Jul 27, 2004 04:50 PM
boost fed ls
Oct 22, 2003 01:53 PM
acman1
Apr 30, 2003 05:31 AM
