boost problems!!!!!!!!!!
Old Jan 17, 2003 | 08:46 PM
gsrcivict's Avatar
Default boost problems!!!!!!!!!!
I went to the dyno today and had nothing but problems. first did a pull to see if switching out my itr cams for stock gsr cams would make a difference.....it did. Got like 6 more horsepower throught the rpm range. ok switch out my mugen chipped ecu with a stock gsr ecu, air/fuel=perfect! kewl! lets adjust the cam gears to get more power! so we advance the intake cam 2 degrees as well as the timing, do another pull and the air/fuel goes to ****! too lean! so we put it back stock. then the boost starts going to ****. jumps to like 8psi @ llike 3000rpm, stays there till like 6200rpm then starts dropping to like 4psi. Im like wtf? anybody got any suggestions on why this may be? I have a rev hard stage 2 t3/4 turbo on a 95gsr with je pistons to 9:1 compression. thanx!
Gabe
Old Jan 17, 2003 | 08:54 PM
Drew Peacock's Avatar
Default Re: boost problems!!!!!!!!!! (gsrcivict)
What are you using for tuning? Perhaps you were detnating so badly you couldn't make any boost Either that or perhaps your leaking boost some how blow off valve? intercooler piping?
Old Jan 17, 2003 | 08:57 PM
gsrcivict's Avatar
Default Re: boost problems!!!!!!!!!! (turbozxi)
I was on the dyno to tune and all I have is a stock gsr ecu with a vafc, skunk 2 cam gears, turbonetics wastegate. the air/fuel was right on the dyno it just wasnt holding the boost it built
Old Jan 18, 2003 | 03:39 PM
gsrcivict's Avatar
?????? Im so confused and pissed!
Old Jan 18, 2003 | 04:39 PM
lazerus's Avatar
what kind of boost control are you using?
Old Jan 18, 2003 | 04:48 PM
gsrcivict's Avatar
Default Re: boost problems!!!!!!!!!! (lazerus)
its a manual boost controller but Im not sure on the brand, I am borrowing it from a friend. Im fixing to go reroute alot of vacum lines that we think is the problem. Ill check back here later and let ya know and see if ya have any other ideas. THANX!
Old Jan 18, 2003 | 04:51 PM
lazerus's Avatar
what it sounds like to me is happening is that boost controller is letting the WG see boost (probably a ball and spring type) but it is not bleeding off a small amount of pressure in the line to the WG, thus keeping it open, and lowering/varying your boost.
Old Jan 19, 2003 | 08:58 AM
gsrcivict's Avatar
yea tha is the type that I have(ball and spring) last night I just took it off and now its building like 5psi and staying there so now Im going to try some other thingsthanx fo rhte help man. Ill be back!
Old Jan 19, 2003 | 09:30 AM
LS-hatch's Avatar
my vote is defiantely on the forms of boost control, not the tuning.
EJ1B18c
Jul 24, 2010 07:15 AM
b00sted EK
Oct 10, 2009 03:43 PM
tony1
Jun 14, 2009 06:27 AM
CALC!_JUST_du_IT!
May 9, 2008 12:14 AM
BlackLudeSi
Sep 8, 2005 07:45 AM
