Boost Problem PlZ HELP
Old Mar 13, 2011 | 04:10 PM
HondaBoy954's Avatar
Default Boost Problem PlZ HELP
aight got an ls vtec on boost...im running chrome and everytime i boost the car i have to turn the car off then back on or it will die out. WTF is the problem...ive changed my map..ran a 3bar map...and the car also will not go into vtec on the dyno but will in the streets....plz help.
Old Mar 13, 2011 | 04:12 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Boost Problem PlZ HELP
Wiring issue more than likely
Old Mar 14, 2011 | 04:26 AM
fcluddington's Avatar
not sure about chrome but i think you have it set wrong put this in the ecu section those guys might have more insight. like your ect is to hi, there are a lot of places to set vtec control. try looking at them
Old Mar 14, 2011 | 01:41 PM
crashtke's Avatar
Did you scale the ecu for the new ap sensor?
Old Mar 15, 2011 | 05:32 AM
we set the map for the 3bar....and vtec control is set properly...also when u downshift from 5th to 3rd the car die when ur pressing the gas??????WTF
Old Mar 15, 2011 | 11:02 AM
wantboost's Avatar
Who is Mr Robot?
bad rom burn, bad tune, bad ecu... tuner is an idiot? wiring issue, etc.
way too many variables. we need way more info to even begin to help
Old Mar 15, 2011 | 12:07 PM
SovXietday's Avatar
This may be a really obvious question, but the obvious answer isn't there.
Wideband readings?
liljukmoves
10
Jun 29, 2011 07:59 PM
pacey
13
Sep 30, 2007 10:13 PM
psychopunk627
25
Sep 8, 2007 06:37 PM
tcontesh
Apr 12, 2006 04:48 PM
philliecrx
Jun 28, 2005 10:21 AM
