boost with no load on motor?
Old Jun 22, 2003 | 12:26 PM
MachAF's Avatar
Default boost with no load on motor?
will a boost gauge read greater than 0 psi reving the car when its in nuetral? say 5k rpms? or does it require a load on the motor?
Old Jun 22, 2003 | 12:37 PM
civperc's Avatar
Default Re: boost with no load on motor? (MachAF)
this - ( https://honda-tech.com/zerothread?id=389343 ) is a good thread about how boost can build while in neutral.
Old Jun 22, 2003 | 12:51 PM
MachAF's Avatar
Default Re: boost with no load on motor? (untensadude)
hey thanks for you link!!!
Old Jun 22, 2003 | 01:07 PM
civperc's Avatar
no problemo
Old Jun 22, 2003 | 02:18 PM
Flamenco-T's Avatar
load drives the turbo, not RPM, it's harder to get your RPM higher at higher gears or in gears but you're producing a lot of loads that revving at neutral which is easy to get your RPM high, but there is no load out of the manifold to drive the turbo
stan
Old Jun 22, 2003 | 04:51 PM
MachAF's Avatar
Default Re: boost with no load on motor? (Flamenco-T)
thanks stan.
everything that could go wrong has with my turbo install.
first fuel rail stud breaks, 3 diff auto parts store to finally find one.
today oil line leaks when I had kit all put together.
Take everything out, manifold turbo, IC piping, radiator to get the damn oil pressline tighten up. Then when I was putting the banjo fitting back on, ******* bolt breaks..WTF. So now I'm stuck waiting for auto parts store to open tomorrow and get one after work. UGH. Drained the oil 3 times so far during this install..GRR.. I'm getting irritated. I'm done for today. I'll start tomorrow agian after work.
Modified by MachAF at 8:07 PM 6/22/2003
RACINGLIFE
Jun 20, 2004 07:26 PM
92b16vx
Feb 25, 2004 09:28 PM
slowspool
Feb 14, 2004 05:35 PM
bluedelsol
Oct 27, 2002 11:21 AM
falcongsr
Nov 9, 2001 11:34 PM
