Boost Issues
Old Jun 4, 2008 | 05:22 AM
Mikato Soul's Avatar
Default Boost Issues
Im running a intercooled t3/t4 turbo on a h22a and im having problems going into boost. Ive already done the basic trouble shooting(checking for leaks, rechecking my vacume sources etc.) what else could cause the motor not to go into boost. The blow off valve releases like its supposed to but its not as powerful as it should be. Im running a Tial Blow off Valve, Tial Waste gate, and FMU. Any other things I should Check?
Old Jun 7, 2008 | 05:51 PM
transpro's Avatar
Default Re: Boost Issues (Mikato Soul)
Check your timing belt to make sure that you aren't off a tooth and timing is retarded or something.
Exhaust will be very hot at idle, if ignition timing is retarded.
93civciv
Dec 4, 2007 05:23 PM
supabang
Jul 31, 2007 05:52 PM
TurboHondaGuy
Nov 9, 2004 05:33 PM
DohcVtecCrx
May 16, 2004 06:40 PM
pipes
Feb 20, 2004 09:19 AM
