boost?how much on stock b16
Old Mar 27, 2005 | 02:53 PM
str8boost's Avatar
Default boost?how much on stock b16
i have a crx jdmb16 wit t3t4 turbo, wit all the bolt ons, stock internals, running aem ems 30-1040u. going to get tuned, how much boost should i run?? got the gm boost solenoid , and 3 bar map....
Old Mar 27, 2005 | 03:29 PM
nsxmatt's Avatar
Default Re: boost?how much on stock b16 (str8boost)
If tuned right you can run up to 300whp on a stock B16. There is no set amount of boost. Do a search and you'll find many threads with the same topic.
Tchleung's Avatar
Try searching first man.. You'll get all your answers there.
Old Mar 27, 2005 | 06:29 PM
Blue98Ex's Avatar
Default Re: (Tchleung)
It horsepower you need to worry about not boost. But just keep it under 300 and it should be fine. As long as you dont run it at 300 all the time.
Old Mar 27, 2005 | 08:49 PM
unclepowers's Avatar
Default Re: (Blue98Ex)
u should be ok on eight to ten pounds but don't push it..make sure u buy high octane gas also...and u not running lean up top or TOO rich..
Old Mar 27, 2005 | 08:59 PM
Tchleung's Avatar
Boost as much as you need to to get the hp/tq you are looking for.
Old Mar 28, 2005 | 05:11 AM
str8boost's Avatar
thanks guys, i think im goin to just tell the tuner to make 285 whp, however much boost it takes
Old Mar 28, 2005 | 05:27 AM
vtekthis's Avatar
Default Re: (str8boost)
i made 340, on a stock b16 and it lasted for 6 months until i got boost happy. that was with 11 psi
Old Mar 28, 2005 | 05:42 AM
Mad Cow's Avatar
Default Re: (vtekthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">i made 340, on a stock b16 and it lasted for 6 months until i got boost happy. that was with 11 psi</TD></TR></TABLE>
What gave?
Old Mar 28, 2005 | 08:24 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">Boost as much as you need to to get the hp/tq you are looking for.</TD></TR></TABLE>
Old Mar 28, 2005 | 08:31 AM
Tchleung's Avatar
Default Re: (Mad Cow)
My first guess would be Ringlands
Old Mar 28, 2005 | 10:09 AM
vtekthis's Avatar
yes your correct!! the ringland on cyl 3 went. but i was good untill i upped the boost with no further tuning. But it still went 13.0 @104 with 60 psi of compression
Old Mar 28, 2005 | 10:30 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">yes your correct!! the ringland on cyl 3 went. but i was good untill i upped the boost with no further tuning. But it still went 13.0 @104 with 60 psi of compression </TD></TR></TABLE>
Yep, Detonation.. Always happens on the leanest cylinder(#3)..
Old Mar 28, 2005 | 11:28 AM
Benjithx's Avatar
Default Re: (tgreaves)
https://honda-tech.com/zerothread?id=1189737 Bulletproof that bad boy
choua01
Feb 24, 2009 08:41 PM
honda_mike
Oct 29, 2008 10:46 AM
ITRBOY1433
Oct 10, 2008 03:54 PM
rustydusty1717
Jun 23, 2008 05:27 PM
projectTeG
Nov 7, 2003 06:56 PM
