boost gauge needle shakes
Old Jul 30, 2009 | 11:26 PM
turbo gsr2000's Avatar
Default boost gauge needle shakes
hey i just wanted to know if any1 had this happan to thar boost gauge when im WOT at like 10psi the boost gauge dos not shakes but at 15psi the boost gauge needle shakes like crazy like 15psi it starts to shake like crazy and starts going to 15psi to 12psi like it shakeing that back
Old Jul 31, 2009 | 06:21 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: boost gauge needle shakes
try a new gauge. still happens they check all your hoses and piping
Old Jul 31, 2009 | 03:15 PM
Bailhatch's Avatar
Try a restrictor in the line. A hole about 20-30 thousandths will help dampen the pulses. you could get a small piece of plastic and melt a hole through it with a hot needle or something just to test it out. Also try hooking up the line to another boost/vac source if that doesnt work.
Old Jul 31, 2009 | 10:12 PM
turbociv910's Avatar
Could be getting pulses from a cylinder. Try another source.
Old Aug 1, 2009 | 05:36 AM
B6tPoweredMx3's Avatar
Make sure that if you are running an external wastegate dump that nothing is blocking the end of the pipe.
Old Aug 1, 2009 | 10:18 AM
mike93eh2's Avatar
my mechanical gauge does the same thing.. its hooked to the back of my edelbrock manifold.. but when logging hondata boost psi is steady as can be. think the hose going to the boost gauge is too big? or just try another source?
Old Aug 1, 2009 | 11:37 AM
Bailhatch's Avatar
There is a reason that many mechanical gauges have a small orifice/restrictor built in.
Old Aug 1, 2009 | 12:04 PM
ya im going to check this.. the hose do look a little big but thanks for the replys
Old Aug 1, 2009 | 01:00 PM
mike93eh2's Avatar
i guess mine doesnt have one thats built in...
Old Aug 1, 2009 | 02:18 PM
Bailhatch's Avatar
I would guess not. It's a really easy fix most of the time. Here is a picture of an old greddy boost gauge I had in the kitchen. Try it out...
Old Aug 1, 2009 | 02:44 PM
thanks for the pic
Old Aug 2, 2009 | 08:32 AM
mike93eh2's Avatar
ill try that but i usually just watch the boost o the neptune tunerview
Old Aug 4, 2009 | 09:07 AM
Nasty Nick's Avatar
New User
My boost gauge was doing this also. I took it to my local tuner shop and they checked it out. Turned out i had a leak in my external wastegate's gasket. They replaced it and now the shaking has gone away.
Old Aug 4, 2009 | 10:40 AM
thanks for all the replys
Old Aug 4, 2009 | 11:02 AM
mike93eh2's Avatar
i dont think thats my problem because logging it in hondata shows it staying steady as can be..now i just need to figure out howto make a restrictor for my hose goign to the boost gauge.
skuded
Apr 21, 2011 04:38 PM
roni_xxp
Engine Management and Tuning
Mar 26, 2009 09:37 AM
vangc6780
Apr 26, 2005 10:10 PM
