Boost gauge broken
Old Dec 21, 2003 | 08:01 PM
RedTegLS's Avatar
Default Boost gauge broken
Is there a way to take a boost gauge apart and make the needle go back to 0? When my car is off the guage reads 2psi. Which I would imagine would make my readings off the whole time! help!
Old Dec 21, 2003 | 08:27 PM
99B16Si's Avatar
if u pull the light out its slot u might be able to get ur pinky in there and adjust the pressure ring by applying physical pressure to it. when u touch the ring your boost gauge will go up, if u push it too hard it will actually stay a little higher than what it thinks is atmospheric pressure. probably not the best way to do it but it should work
Old Dec 21, 2003 | 08:30 PM
RedTegLS's Avatar
Default Re: (99B16Si)
Unfortunately I need the needle to go down.
Old Dec 21, 2003 | 08:33 PM
99B16Si's Avatar
sorry i read it wrong....i have no idea how to fix that, sorry
Old Dec 21, 2003 | 09:03 PM
t04ecvc's Avatar
Default Re: Boost gauge broken (RedTegLS)
I'm guessing its an autometer gauge. If it isn't then sorry. If it is, its pretty common and I would upgrade to a better gauge with a sending unit like a greddy gauge.
Even if you could fix the gauge, would you trust it?
s2kkid
Mar 8, 2006 03:57 PM
civicsi940
Jan 26, 2006 01:36 PM
DaZman69
Dec 21, 2004 11:34 AM
fishnfst
Jul 31, 2004 04:00 PM
FredoSP
Oct 24, 2002 08:05 AM
