boost gauge and bov question???
Old Aug 29, 2009 | 06:03 PM
imationdawg's Avatar
Default boost gauge and bov question???
my first question, when i start my car is the boost gauge needle suppose to move or does it just stay still untill i rev to a certain rpm? second question, i have a 50mm tial bov and i was wondering if it was suppose to stay open during idle and close when i give it some throttle?
Old Aug 29, 2009 | 06:54 PM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
Default Re: boost gauge and bov question???
1. When you start the car the boost gauge is supposed to read -20ish Vac.
2. There is a lot of controversy between the correct answer, when you think logically the BOV is supposed to open to release pressure, but it opens due to there being a vacuum not actual pressure forcing it open. Some stay open some don't, do I know the correct answer no, but I would assume that a open BOV at idle is safer for your turbo internals and TB since it is more sensitive to you letting off the throttle. Some BOV's come with a air filter.
Old Aug 29, 2009 | 07:31 PM
my gauge doesnt move at all. i have it hooked up to a vaccum block. its a autometer c2 gauge, anyone know why it aint moving?
Old Aug 29, 2009 | 07:54 PM
dpetro1's Avatar
mechanical or electrical gauge?
if its mechanical, make sure the line isnt pinched under the dash somewhere, happened to me once. if its electrical, make sure the solenoid is hooked up and wired correctly.
tial 50mm open at idle is perfectly fine. as you mentioned it closes immediately once you apply the throttle.
Old Aug 29, 2009 | 08:05 PM
its mechanical, and it wasnt pinched... any other ideas? the positive wire and ground wire dont have to be hooked up for it to work rite?
Old Aug 29, 2009 | 08:19 PM
CD5_530's Avatar
the wiring should be for the illumination only
Old Aug 29, 2009 | 08:24 PM
wilham320's Avatar
does the gauge read vacuum and boost or is it just boost/pressure?
you either have a bad gauge or a big leak somewhere in the line or at the vacuum block.
where is the block hooked into?
HeavenSentRose
Jul 29, 2009 04:53 PM
esedulerp5tenin
May 21, 2007 02:56 PM
mattcalica
Jan 13, 2004 10:13 AM
_Endless_
Nov 18, 2003 10:32 PM
dragtaccord
Oct 17, 2002 11:57 AM
