Boost Drop
Old Oct 14, 2007 | 08:57 PM
lo0nY's Avatar
Default Boost Drop
already search, and can't find an answer....running a ls with a drag kit for a while, with a Tial wastegate with a 7lb spring, car's been running good. Installed a Profec B v2 and boost at 9lb really good, after that first run, the car won't hold boost. 1st gear 2psi drops to 0, 2nd gear 5lb drops to 0, 3rd gear 7lb drops to 0, it won't hold boost at all...checked all the vacuum lines, everything is good, checked for exhaust leak, couldn't find anything, replace the wastegate with a deltagate, same problems......guys have any ideas what it could be? also i pulled the boost controller out thinking it was it.....but it wasn't
Modified by lo0nY at 6:08 AM 10/15/2007
Old Oct 15, 2007 | 12:24 PM
lo0nY's Avatar
Default Re: Boost Drop (lo0nY)
bump
Old Oct 15, 2007 | 12:49 PM
HarfordCTR's Avatar
Did you check your manifold and charge pipes for leakes?
Old Oct 15, 2007 | 12:52 PM
lo0nY's Avatar
Default Re: Boost Drop (HarfordCTR)
yep....
s2kseven
Apr 24, 2018 09:11 AM
j.packsb
Dec 9, 2010 04:28 PM
90Rexx
Aug 11, 2010 05:05 AM
Adub33
May 2, 2003 11:15 AM
Dee
Nov 22, 2001 06:39 PM
