boost d16
Old Sep 30, 2003 | 09:53 PM
OoHiTzToMMy's Avatar
Default boost d16
im about to put my turbo into a stock d16z6 i was wondering how much boost can i push with stock internals....and could my motor handle 200whp....remember motor is all stock maybe uprade fuel pump
Old Sep 30, 2003 | 09:59 PM
civperc's Avatar
Default Re: boost d16 (OoHiTzToMMy)
search function is your friend. you'll find everything you need and more.
Old Sep 30, 2003 | 11:36 PM
Default Re: boost d16 (untensadude)
is it ture that you could put ls rods into a d16z6?
Old Sep 30, 2003 | 11:46 PM
Drew Peacock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoHiTzToMMy &raquo;</TD></TR><TR><TD CLASS="quote">is it ture that you could put ls rods into a d16z6?</TD></TR></TABLE>
With modification. its all been asked and answered try a search under" turbo sohc" make sure you check the archived files.
Old Oct 13, 2003 | 09:21 PM
what kind of injectors fit on a d16z6 that honda makes
Old Oct 13, 2003 | 09:36 PM
beerbongskickass's Avatar
Default Re: (OoHiTzToMMy)
With proper tuning 200 whp would be fine on stock internals. I have the same engine and will also be turbochaging it soon with stock internals. I am going to be using hondata and DSM 450cc injectors for fuel management. You will need a resistor pack from a CRX or you will have to get resistors from radio shack to install the DSM injectors. Do some searching and more than likely you will find the answer to most of your questions.
racinskittle's Avatar
DSM 450cc injectors. I've hit 9psi, but it's at 7psi daily. Yes a stock D16z6 can make well over 200WHP.
Will yours? Prolly wont last long enough to find out
Old Oct 14, 2003 | 04:47 PM
Cee_mon's Avatar
I am hoping to get 200whp TUNED with this setup..
d16z6 greddy kit tdo4
drag 1 FMIC
turboxs MBC at 8psi now...10 at tuning
VAFC/DSM 450/walbro 255
highflow cat with 2.5in piping to magnaflow
Old Oct 14, 2003 | 05:25 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoHiTzToMMy &raquo;</TD></TR><TR><TD CLASS="quote">....remember motor is all stock maybe uprade fuel pump</TD></TR></TABLE>
That's the best I have heard all day..........."maybe an upgraded fuel pump"....I think you need a little more research before you decide to turbo anything.
lilshady6796
Sep 5, 2009 08:13 AM
Black95CivicEx
Dec 30, 2008 02:11 PM
sasinorm01
11
Apr 12, 2007 08:27 PM
nekoabandoned
Nov 26, 2005 11:28 AM
PHILLIPDEEZ
Apr 21, 2005 02:02 PM
