boost cut at 11.6lb with 3bar what is problem?
Old Jun 17, 2004 | 07:27 PM
60-1teg's Avatar
Default boost cut at 11.6lb with 3bar what is problem?
My car is a 95 gs-r with max- rev turbo kit t3/t04e 9:1compression I have a GM 3BAR map and it is wired correctly. I am running hondata s200 w/boost and on the dyno it was hiting boost cut at 11.6lbs. Like i said but the part# on the 3bar is 12223861. I know this is 3bar but my tuner said boost cut in the rom of the hondata was off so it should boost to what ever boost is set at right? I think that the boost cut in the rom is messed up in his computer. My car runs in tip top shape
could it be my map sensor or do you think his hondata on his computer?
Thanks for any help on this subject.
Old Jun 17, 2004 | 07:41 PM
60-1teg's Avatar
Default Re: boost cut at 11.6lb with 3bar what is problem? (2.0lhatch)
bump
Old Jun 17, 2004 | 10:03 PM
60-1teg's Avatar
bump for the night
Old Jun 17, 2004 | 11:26 PM
FastEK9's Avatar
Make sure the 3bar option is selected in the romeditor, and the boost cut either turned off or up.
Old Jun 18, 2004 | 04:17 AM
PM-Performance's Avatar
he prob has the boost cut set. the deffault is 11.9psi i think off hand.
but if it was set for the incorrect map sensor the car wouldnt even run right, so its prob not that.
Old Jun 18, 2004 | 05:55 AM
ladysman's Avatar
Default Re: boost cut at 11.6lb with 3bar what is problem? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">he prob has the boost cut set. the deffault is 11.9psi i think off hand.
but if it was set for the incorrect map sensor the car wouldnt even run right, so its prob not that. </TD></TR></TABLE>
The default is 11.2 if the stock sensor is selected I know. Not sure what it is ifyou put the 3 bar option on. I bet it doesn't change.
Old Jun 18, 2004 | 06:07 AM
Turbocivic94's Avatar
Default Re: boost cut at 11.6lb with 3bar what is problem? (ladysman)
its probably the boost cut and make sure u r not creeping
Old Jun 18, 2004 | 04:54 PM
60-1teg's Avatar
Default Re: boost cut at 11.6lb with 3bar what is problem? (Turbocivic94)
3bar is selected in romeditor and boost cut was turned off still boost cut at 11.6 and like I said before it runs like a top. We switched out to another 3bar map same thing do you think it is romeditor was stuck not letting tuner turn off boost cut and showing him that it was off but it was still on ?
Old Jun 18, 2004 | 05:08 PM
JDMCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
The default is 11.2 if the stock sensor is selected I know. Not sure what it is ifyou put the 3 bar option on. I bet it doesn't change.</TD></TR></TABLE>
Weird i have the stock mapsensor and i hit .93 Bar today and the car pulled real hard.
Old Jun 19, 2004 | 03:00 PM
60-1teg's Avatar
Default Re: boost cut at 11.6lb with 3bar what is problem? (JDMCRX)
bump
EJ8 GSR-T
Apr 11, 2006 07:14 AM
philipwight
May 4, 2004 08:48 PM
Nextelbuddy
Mar 16, 2004 09:57 AM
JusT a Cx
Feb 24, 2004 05:58 PM
Ek00fbp
Oct 8, 2003 10:08 PM
