boost creep with profec b. suggestions?
Old Jul 4, 2008 | 10:04 PM
patrick4588's Avatar
Default boost creep with profec b. suggestions?
95 turbo gsr. spoolin quick4 manifold, 60-1, 40mm synapse wg. greddy profec b spec 2.
never had an ebc before, so using it is new to me and im trying to get it all down. basically with the ebc off, i hit 10psi. on 25% duty cycle, it hits 12.5psi by 4300rpms and holds until about 7000, then creeps up to 14-14.5psi by redline (8400). do i need to lower the gain % or start boost? raise it?
Old Jul 4, 2008 | 10:33 PM
rudebwoy's Avatar
sell it!
Old Jul 5, 2008 | 12:11 AM
Outkast95LS's Avatar
Default Re: (rudebwoy)
What do u have your settings at right now? I have the profec B as well, and i dont have any issues with spiking or boost creep. You might wanna adjust the % gain though..
Old Jul 5, 2008 | 05:17 AM
i have the % gain at 60 and the start boost at 10psi
Old Jul 5, 2008 | 10:08 AM
Default Re: (patrick4588)
lower the percent gain, and leave the start boost at 0 for now. Then have a friend drive your car while you play with the controller.
Old Jul 5, 2008 | 10:26 AM
Default Re: (Outkast95LS)
well the start boost is what determines when the gate starts opening right? i dont want it to open at 1 psi!! spool would be the lose
Old Jul 5, 2008 | 11:45 AM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 &raquo;</TD></TR><TR><TD CLASS="quote">well the start boost is what determines when the gate starts opening right? i dont want it to open at 1 psi!! spool would be the lose</TD></TR></TABLE>
He said "for now." As in, get boost to stick at the psi that you want it to and then move up the crack pressure.
Honestly, I just went to an MBC.
Old Jul 5, 2008 | 12:15 PM
the profec is just being used temporarily until i get my solenoid back from tdautoworks to run pwm thru the ecu
Old Jul 5, 2008 | 05:52 PM
dpetro1's Avatar
leave the start boost at 0 until you get consistant. it does help spool up and usually creates spiking not creeping but either way leave it at 0 for now. what are the set and gain values? seems like you will need to adjust the gain a bit
Old Jul 5, 2008 | 07:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrick4588 &raquo;</TD></TR><TR><TD CLASS="quote">i have the % gain at 60 and the start boost at 10psi</TD></TR></TABLE>
Old Jul 5, 2008 | 10:51 PM
dpetro1's Avatar
i fail at reading. turn the gain down and see what happens. keep start boost at 0
VtecKiDD
Nov 18, 2006 03:54 PM
SloB16crxMike
Aug 15, 2006 10:31 AM
Drkaccrd
Jun 7, 2005 09:28 PM
TurbothisLS
Sep 8, 2002 09:31 PM
