boost creep near redline?? is that my problem or is something else wrong
Old Jan 20, 2006 | 09:01 AM
blackeg's Avatar
Default boost creep near redline?? is that my problem or is something else wrong
well ive heard of this happening on high hp/flow setups, but i dont think im making much over 300hp.
setup:
ls/vtec
ramhorn mani
57 trim t3/t4
tial 38 .5 bar spring
3" downpipe with e cutout
hallman mbc turned all the way down.
finally took the car out for real the other night. its holding a solid 10-11 psi (off the 7.25psi spring, open cutout) but from like 7500-8500 rpms the boost makes it way up to 13 or so psi. my passenger said i hit 15 psi once, which im not keen on because i dont have fuel/tuning up that high right now.
vacuum lines are all hooked up and whatnot, what do you guys think is happening?
Old Jan 20, 2006 | 09:04 AM
adseguy's Avatar
Default Re: boost creep near redline?? is that my problem or is something else wrong (blackeg)
My Neukin ram horn manifold does the same thing. I boost around 16 PSI but it'll creep to 17 or 18 by 7000rpm. We pretty much have the same setup, but I think it's just the wastegate placment on the manifold. . Oh well, I'm not too worried about it since it's tuned for it. GL on the fix
Old Jan 21, 2006 | 08:23 PM
blackeg's Avatar
Default Re: boost creep near redline?? is that my problem or is something else wrong (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">My Neukin ram horn manifold does the same thing. I boost around 16 PSI but it'll creep to 17 or 18 by 7000rpm. We pretty much have the same setup, but I think it's just the wastegate placment on the manifold. . Oh well, I'm not too worried about it since it's tuned for it. GL on the fix </TD></TR></TABLE>
yea man, once i get larger injectors i wont give a rat's ***, its just right now im way on the borderline of my current ones, so i dont have the fuel should i hit much more than 12 psi. i was rompin on it good today and i didnt see over 12 psi.
Old Jan 21, 2006 | 08:42 PM
93turbo16's Avatar
If everything is hooked up correctly, it could just be as easy as wastegate placement on the manifold. I have had a few setups that do that, and its hard to get around it sometimes.
Old Jan 22, 2006 | 05:34 PM
dntbh8n's Avatar
Default Re: (93turbo16)
bump i dont know Sh*t about boost lol
Old Jan 22, 2006 | 07:53 PM
Acrappyhatch's Avatar
what wastegate are you using?
Old Jan 22, 2006 | 11:09 PM
blackeg's Avatar
Default Re: (Acrappyhatch)
tial 38mm. it happend again tonight, and im pretty sure it cost me the motor. oh well
Old Jan 23, 2006 | 10:00 AM
blackeg's Avatar
Default Re: (blackeg)
yep, definately cost me the block and pistons.
IF YOUR ENGINE MANAGEMENT HAS A BOOST CUT FEATURE, USE IT.
thats my advice to anyone who might read or search this later on.
crvtectim
Feb 14, 2012 12:54 PM
iTz On!!!
Mar 18, 2008 06:10 PM
Topdawgg
Jul 18, 2006 04:20 AM
BB6-213
Jun 10, 2004 05:08 AM
cajnatc
Jun 13, 2003 07:43 AM
