Boost "creep"
Old Mar 15, 2011 | 12:36 PM
  #26
spoolinvtec54's Avatar
Default Re: Boost "creep"
i had the similar problem with that mani. I was running 11psi but it was droping down 9.
Old Mar 15, 2011 | 12:45 PM
  #27
SovXietday's Avatar
Uh, how is that at all similar?
unless both my old cheapo wastegate and the brand new tial are leaking internally, then im 100% sure that i have no vacuum leaks. ive checked both ports on the old and new wastegate to see if theyre leaking, they arent. check the port on the compressor, no leaks. checked the line going from the compressor to the bottom port on the waste gate, zero leaks. same with the BOV
Looks like the real deal to me. It doesn't sound like a vacuum leak to be honest, if you hear that wastegate crack totally open at 8psi with an 8psi spring then you do not have a leak. But the question is always worth asking.
Good luck with it!
Old Mar 15, 2011 | 02:57 PM
  #28
thatHEMIguy's Avatar
yeah i hear it crack open at 8 and now at 11 since i have the 11lb in the wastegate.
Just deciding between two different manis now. one is a ramhorn made my AFI on here and the other is a cc fab top mount. the top mount comes with a DP and is 525 shipped just needs to be rewelded in a couple spots. the ramhorn doesnt come with a DP and just needs to be drilled out to fit a t3 flange and is 400
Old Mar 19, 2011 | 08:22 PM
  #29
q16racer's Avatar
Time for 400!
powerdbygarrett
Jul 3, 2008 01:50 PM
Nextelbuddy
Jan 2, 2007 12:55 PM
Tooned
Oct 29, 2005 12:58 PM
_Cyclone_
May 4, 2005 02:32 PM
booscivic
Sep 5, 2003 02:34 PM
