boost creep
Old Jun 25, 2010 | 09:45 AM
EFboostedSI's Avatar
Default boost creep
ok im running a 8psi spring in my tial gate, im creeping up to 12. ive just put new internol to make sure its not the gate sticking. but its still doing it could it be the wastegate or manifold. http://cgi.ebay.com/ebaymotors/1990-...Q5fAccessories
thats the manifold i have well at least they look the same. idk what it could be ive redid all my vacumm lines i dont have any leaks.
if u need to know set up its a
b18a1 swap in an ef turbo is a 50trim
thanks for help
Old Jun 25, 2010 | 10:24 AM
dpetro1's Avatar
Default Re: boost creep
probably due to the poor wastegate placement on the manifold.
also make sure you chain the wastegate down to the engine or something so you dont lose it when the wastegate pipe cracks and falls off the manifold.
Old Jun 25, 2010 | 08:33 PM
lol yea had that happen before on a different manifold. tell u the turth this manifold ive got has been holding up really good (-) the boost creep. it was only 10 but i pull the charco can off the car and it was at 12 idk if that can was working at a boost leak for something probley so really.
but still no body on here thinks its the wastegate not keeping up. if not anyone got any set to look at good built manifold for the bseries i dont really want to have a boost sprick cuz of this manifold thats on the car or is there anything i can do with what ive got to make it work better.
Old Jun 26, 2010 | 04:38 PM
dpetro1's Avatar
i would just get a good manifold. the problem with the one you have is that the wastegate pipe is at more than a 90* angle from the exhaust flow, making it hard for the gases to escape through the wastegate opening. so they continue into the turbo making it spool up more.
Old Jun 26, 2010 | 05:14 PM
yea thats what me and my buddys are figureing its the manifold. im just wanting to make sure that the 38 tial is able to handle it which it should there shouldnt been a problem. im just trying to get more opinion that way im not buying a manifold and wastegate.
Old Jun 26, 2010 | 05:35 PM
azandford's Avatar
just run a log like the go-autoworks which has good wg placement... that thing is going to crack on you
Old Jun 28, 2010 | 04:35 AM
dpetro1's Avatar
as long as its a genuine tial wastegate, i can guarantee that's not the problem
Old Jun 28, 2010 | 03:47 PM
cjordan's Avatar
x2
Old Jun 28, 2010 | 05:22 PM
yea its a true tial
and for the lug manifold, ive ran one before and didnt like it at all please i had to make a pipe to move the wastegate so it didnt hit my hood. i really like the flow of the ram horn manifold but im not sure of brands. what some good brand
Old Jun 29, 2010 | 04:50 AM
dpetro1's Avatar
Originally Posted by EFboostedSI
yea its a true tial
full-race, peak boost, afi, spoolin performance. check the sponsor section
civic-r11
Feb 7, 2012 07:03 PM
wtsapexipowerfc
May 29, 2010 07:58 AM
AutoLab
Jun 30, 2007 07:15 PM
IntegraMastaz
Feb 8, 2006 09:33 AM
dtec
Aug 10, 2003 02:25 PM
