boost creep
Old May 23, 2010 | 09:32 AM
delslow1975's Avatar
Default boost creep
i had a tial 38mm wastegate had bad boost creep so my tunner told me to get a bigger wg. so i got the pricision 46mm he told me to put a small spring in it to help not have creep. we put the 6lb spring in and it still boost creep to 16lbs. wouldnt a bigger spring help stop boost creep.
Old May 23, 2010 | 09:35 AM
street_ride14's Avatar
Default Re: boost creep
post a pic of your manifold
Old May 23, 2010 | 12:05 PM
Old May 23, 2010 | 12:54 PM
GT35R_EF's Avatar
Make mine whatever you want
The cheap manifolds like that are notorious for creeping because they have horrible wastegate placement and design. If it's creeping from 6 to 16, I doubt there is anything you can do to fix it. I wouldn't waste time modifying the manifold, just buy a better manifold and use the 46mm.
Old May 23, 2010 | 03:44 PM
will do bro thanks. looking at the ram with the wastegate coming out infront of the manifold
Boosted00
Jan 19, 2018 01:51 PM
BeArDy
Welding / Fabrication
Aug 26, 2011 01:52 PM
turbohatch96y7
Jul 12, 2009 01:52 PM
blackeg
Mar 18, 2008 09:31 PM
KStuned
Dec 8, 2003 11:52 PM
