Boost Creep
Old Jun 11, 2005 | 09:41 PM
2kTeg's Avatar
Default Boost Creep
ok i hit 9lbs in 1st 9lbs in 2nd and then when i get to about 4.5 in 3rd the boost just starts creepin 10,11,12,13 then i shut it down. It does this consistantly.. it will hold and 9 in 3rd to untill it hits higher rpms i need help i don't wanna blow this motor up like that last one
Old Jun 11, 2005 | 09:42 PM
mr_magoo's Avatar
Default Re: Boost Creep (2kTeg)
get a bigger wastegate
Old Jun 11, 2005 | 09:46 PM
2kTeg's Avatar
Default Re: Boost Creep (mr_magoo)
its a stock 14b turbo with internal wastegate
Old Jun 11, 2005 | 09:52 PM
90 integra's Avatar
what kinda of wg are you using?
Old Jun 11, 2005 | 10:01 PM
dc2legend's Avatar
Try boring out the area around tha flaper for better flow. Might help a bit.
Old Jun 12, 2005 | 09:55 AM
2kTeg's Avatar
Default Re: Boost Creep (dc2legend)
im using a stock mistu wastegate on a 14b turbo, the wastegate worked at one point and held, what would cause the boost to hold tell 5 grand and then start to creep hard?
Old Jun 12, 2005 | 10:50 AM
beerbongskickass's Avatar
the internal wastegate is your problem. Get an external tial wastegate.
Old Jun 12, 2005 | 11:12 AM
2kTeg's Avatar
Default Re: Boost Creep (beerbongskickass)
yes thats next in the budget, rent is 1st lol but anyways i fixed the problem i had a tear in my vaccum line that goes from the jpipe to the wastegate thanks for the replies
Old Jun 12, 2005 | 07:44 PM
2kTeg's Avatar
well i thought i had it fixed but its gay it doesn't do it in 1st or 2nd and it holds fine tell higher rpms in 3rd then it just has a mind of its own
Old Jun 12, 2005 | 09:26 PM
used2baracer's Avatar
ha... i've always had trouble with 14b's not holding boost... anyway. here's some suggestions.
A) you don't have a 14b, you have a 16g because t25 & 14b wastegates open between 6-8psi, 8psi being the max on about 10 dsm/honda setups i've done. My first turbo kit was a 16g on a D16y7 and it did exactly what ur describing.
B) You have clocked ur turbo or moved ur wastegate in someway. I always had clearance problems with the wastegates or compressor outlets, and once you move it, you change the way the wastegate functions (boost to)... if this is the case, remount ur wastegate.
C) Your wastegate is broke
if your vacuum for ur wg is off the manifold, this could be a problem. I just recommend moving ur wastegate or bending it/bracing it. the close the actuator is to the arm, the less boost u get. I wouldn't purchase an external wastegate for your setup. Save ur money and upgrade to a better setup. If all else fails, use a spring on your wastegate. Do a search on here or im me if you need help... Late
Old Jun 12, 2005 | 10:34 PM
Default Re: Boost Creep (used2baracer)
The only thing I would have done different when I first built my kit is getting a tial wastegate, instead of using my internal. Being able to control your boost is pretty important if your pushing your motor to the edge. A little spike or creep and you could have a blown motor.
97grnrs
Feb 20, 2006 05:46 AM
Btothe3rdDegree
Mar 16, 2004 12:45 PM
Cowboy
Jun 17, 2003 01:17 PM
turbo se
Jun 13, 2003 11:33 AM
