Boost Controllers - Whats The Tiny Hole For?
Old Mar 7, 2006 | 01:30 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Boost Controllers - Whats The Tiny Hole For?
Im sitting here lookin at my JoeP MBC and its got this little hole drilled into the corner, I cant for the life of me figure out whats its for or why its there
Its like a 1mm hole right in the side
what does this do?
Im kinda new to this so can someone explain to me what exactly a boost controller also can do for an internally wastegated turbo? I can raise boost with this right?
Old Mar 7, 2006 | 01:35 PM
adseguy's Avatar
Default Re: Boost Controllers - Whats The Tiny Hole For? (TurblowEF)
I believe that's the bleeder hole. Don't cover it up
Old Mar 7, 2006 | 01:39 PM
PINKS's Avatar
Default Re: Boost Controllers - Whats The Tiny Hole For? (adseguy)
Why the **** do you want it to bleed your pressure though?
Old Mar 7, 2006 | 01:59 PM
Boilermaker1's Avatar
They bleed the pressure so the wastegate doesn't see it. If the WG sees it then it opens.
Thats the whole purpose of the BC... it delays the wastegate.
Old Mar 7, 2006 | 04:18 PM
I Have an STD's Avatar
wrenchin'
Default Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">They bleed the pressure so the wastegate doesn't see it. If the WG sees it then it opens.
Thats the whole purpose of the BC... it delays the wastegate.</TD></TR></TABLE>
perfect response, thread done, lock it up
Old Mar 7, 2006 | 05:08 PM
PINKS's Avatar
Default Re: (I Have an STD)
That little hole bleeds the pressure? I dont get it then? How is it regulated?
I always thought that the ball was set by the spring so it wouldnt move so far
WTF is the ball for then
Now Im lost
Old Mar 7, 2006 | 07:42 PM
PINKS's Avatar
bump
Old Mar 7, 2006 | 08:28 PM
rmcdaniels's Avatar
The bleeder hole in a checkball controller lets the wastegate close again after you are done boosting, otherwise the checkball would hold the pressure in the line and hold the gate open.
Boilermakers response was correct for a bleeder-type boost controller.
Old Mar 7, 2006 | 08:58 PM
PINKS's Avatar
Default Re: Boost Controllers - Whats The Tiny Hole For? (rmcdaniels)
Whats a bleed type boost controller?
Also, these manual boost controllers work with internal wastegated turbos right? I wanna run my internally gated turbo to 15psi, but its only actuated for 8-10
thanks
Old Mar 7, 2006 | 09:46 PM
Riake's Avatar
http://www.boostcontroller.com...?i=22
Read from about page 4 to the end. It will descibe what the hole is for and the differences between a bleeder type MBC and a ball and spring MBC.
Old Mar 8, 2006 | 02:40 AM
PINKS's Avatar
Default Re: Boost Controllers - Whats The Tiny Hole For? (Riake)
thank you sir, bump for info on internally gated ****
Old Mar 9, 2006 | 01:56 PM
PINKS's Avatar
Can you adjust boost on an internally wastegated turbo with a MBC?
Old Mar 9, 2006 | 02:23 PM
nickromeo's Avatar
that tiny hole is there for the purpose of letting pressure escape a setup where the MBC is on the INTERNAL WASTEGATE ACTUATOR.
because the boost pressure has no where to go, it cant go back into the pressure source, it leaves through the hole.
on external wastte gate, the hole isnt nessessary because boost leaves the external wastegate itself.
Old Mar 9, 2006 | 03:12 PM
PINKS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurblowEF &raquo;</TD></TR><TR><TD CLASS="quote">Can you adjust boost on an internally wastegated turbo with a MBC?</TD></TR></TABLE>
Old Mar 9, 2006 | 10:40 PM
tonydatyga's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurblowEF &raquo;</TD></TR><TR><TD CLASS="quote">Can you adjust boost on an internally wastegated turbo with a MBC</TD></TR></TABLE>
For the love of god, yes
Old Mar 10, 2006 | 04:30 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riake &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.boostcontroller.com...?i=22
Read from about page 4 to the end. It will descibe what the hole is for and the differences between a bleeder type MBC and a ball and spring MBC.</TD></TR></TABLE>
good read for a boost controller noob!
Old Mar 10, 2006 | 06:12 AM
Alfa Turbo's Avatar
Default Re: Boost Controllers - Whats The Tiny Hole For? (2point2)
With all due respect to the previous posts... the hole is there beacuse you get more accurate control (and gauge reading) if flow is dynamic rather than static. The small hole allows for a little flow, not enough to affect spool in anyway yet enough to allow the MBC to do a better job. Better job defined as maintaining your desired boost pressure more consistently and should your boost gauge be hooked up to the same line, a more accurate reading.
Old Mar 10, 2006 | 06:23 AM
1bad-eg's Avatar
Read from about page 4 to the end. It will descibe what the hole is for and the differences between a bleeder type MBC and a ball and spring MBC.</TD></TR></TABLE>Very good link. Very informative.
Old Mar 10, 2006 | 07:20 AM
boostedcivicsir's Avatar
Mr. Badwrench
i did all day from 10 psi to 30 psi on my t type with an internal gate.
Funanin
Jan 10, 2008 05:51 AM
avsrule414
Dec 10, 2005 09:07 AM
blackcivic44
Feb 1, 2005 07:45 PM
FOrSfEd
May 17, 2004 10:13 PM
_Endless_
Jan 8, 2003 11:24 PM
