boost controller question/wastegate
Old Sep 15, 2006 | 06:26 PM
99delsol's Avatar
Default boost controller question/wastegate
i just bought a blitz boost controller,i have a greddy turbo kit ,i think its an internal wastgate set at 6 or 7 psi,do i need to change the wastegate to set the boost higher,how will it work,please give detailed info please so i can understand about this more,thanks for all the input
Old Sep 15, 2006 | 06:59 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: boost controller question/wastegate (99delsol)
if you want the boost like above 30 psi then you will probably need to change the base spring, but i am assuming it is the 18g? and it wont be effecient that high anyway, so no. the 6 or 7 psi spring is the lowest you can run. the blitz will increase from there.
may i ask, dual sbc spec r or s or dual sbdic?
Old Sep 15, 2006 | 08:21 PM
99delsol's Avatar
its the spec s
Old Sep 15, 2006 | 08:36 PM
Mr. Badwrench
Default Re: (99delsol)
i had the spec r, nice controller either way
b20vtech
Jan 24, 2008 05:55 PM
ek9vboi2
Jul 18, 2004 08:14 PM
Screamer
Mar 29, 2003 08:00 PM
M.A.R.C.
Jun 9, 2002 06:31 PM
clean
Oct 18, 2001 11:16 AM
