Inline Pro manifold porting
Old May 12, 2004 | 09:02 AM
Boofster's Avatar
Default Inline Pro manifold porting
Just measured the wastegate port on the mani and it's something ~34mm. I have a 38mm Tial. Is it a good idea to port match it?
Old May 12, 2004 | 09:06 AM
calib17a's Avatar
Default Re: Inline Pro manifold porting (Boofster)
I don't see why not, just use the gasket as a template. Just be careful you don't want any leaks.
Old May 12, 2004 | 09:12 AM
CRX T-Si's Avatar
Default Re: Inline Pro manifold porting (calib17a)
While your at it why don't you clean up the ports a little and matchport the turbine housing to the exhaust flange on the manifold.
I did that with my Revhard.
just place the gasket on the manifold and shave the gasket to match that port. then take that gasket and match it to your turbine housing.
Always wear googles and get a good mask so you don't inhale too much dust.
Old May 12, 2004 | 11:34 AM
Boofster's Avatar
Default Re: Inline Pro manifold porting (CRX T-Si)
Has anyone done this to their IP?
Old Oct 17, 2004 | 03:13 PM
Boofster's Avatar
Ok, I'm ready to get this done. What drill works best? I saw a bunch of wood tools at sears, they were round and didn't look right. The port drill bits looked better but 38mm = 1.5" and I couldn't find a metal one in that size.
Is there a better tool for this? I'd assume a tapered cylinder of somekind would work much better.
Old Oct 17, 2004 | 04:51 PM
97hb's Avatar
Your gonna need a tungsten carbide bit. All else will just melt
Old Oct 17, 2004 | 04:52 PM
Boofster's Avatar
Default Re: Inline Pro manifold porting (97hb)
Good to know...and do i get that overnighted from Japan or what?
Old Oct 17, 2004 | 08:25 PM
88gts's Avatar
Yeah and the drill will have to come from china I guess LOL>..go ahead and try a HSS bit on cast iron with a drill LOLOL.
Old Oct 18, 2004 | 01:29 PM
turtle-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I'm ready to get this done. What drill works best? I saw a bunch of wood tools at sears, they were round and didn't look right. The port drill bits looked better but 38mm = 1.5" and I couldn't find a metal one in that size.
Is there a better tool for this? I'd assume a tapered cylinder of somekind would work much better.</TD></TR></TABLE>
I think an air die-grinder would work best with a deburring tip. If you don't have access to an air compressor, then maybe a dremel, but I think it would take much longer on the dremel because it's much weaker.
accord99power
Jan 20, 2011 08:41 AM
Powelly
Sep 23, 2007 12:41 PM
Axle
Welding / Fabrication
49
Aug 3, 2006 10:04 AM
trbob16a
Feb 5, 2004 05:45 AM
accordexchange
May 14, 2003 08:15 PM
